Dead Ideapad 14 ADA previous repair attempt
  • NanoPat
    • Jan 2023
    • 11
    Hi guys.
    I got a Lenovo 14 ADA Laptop from another shop. They tried to flash the bios with a clip after the device was without any signs of life. Obviously its not posting and they nocked of a small parts arround the eeprom. Doesnt matter at least, replaced allready from a donor. The rest of the board looks fine.
    Iam pretty new in this area but they begged for help and I want to learn something about it. Doesnt matter how it ends.
    I decided to unsolder the Winbond W25Q64JW and make a dump with ezp in first step but I am wondering if I read out bananas. I downloaded official bios and extracted with rc2 etc. and command line to have a comparison. It looks way different but still hoping Iam wrong
    With removed EEPROM the behaviour of the device ist still same, so Iam pretty sure that a working bios will fix it. Also Iam wondering if theres any backup Bios but cant find anything.
    Anybody any ideas? Thanks in advance. I attached the dump I made and the cap file from official bios. Can somebody confirm that the dump is not corrupted?
    If I missed any information Iam sorry, just give me a hint.
    Last edited by SMDFlea; 02-10-2023, 01:39 AM. Reason: not the bios requests sub forum
  • reformatt
    • Feb 2020
    • 1499
    Re: Dead Ideapad 14 ADA previous repair attempt
    Do you think they actually rewrote the BIOS or is what you have the original? Your dump is better posted in the BIOS requests group and one of the legends there will repair it if needed. The one you dumped seems ok in UEFI tool.
    Updates from the OEM's usually are only a partial BIOS, and don't have any of the DMI info needed. There's no one size fits all, and it's a bit of black art so best left to the guys who frequent that group.
    Whilst a corrupted BIOS is a common issue, you don't start with that when you are dealing with a dead laptop. A lot of things have to happen before BIOS code is even read.
    • NanoPat
      • Jan 2023
      • 11
      Thanks for ur reply dude.
      Since this guys played arround with the bios I wanted to have a clean base before tracing chiplevel issues. I was kinda confirmed when I removed the EEPROM and the device shows exactly the same behaviour. As the device turns on, power led is on, fan is spinning for a short while and also the charger is recognized Iam guessing theres nothing wrong with it except it seems not to be able to post. The usual things allready done like different known good RAM, unplugged all unnecessary periphery etc.
      Also Icannot find any free boardview or schematic for it to have readings and a clue about the circuits. Waiting for replys in this case but I want to make sure to have a working Firmware flashed before wasting time. Might be the wrong thoughts
      Later when Iam home Ill check if theres anything suspicious in the ps circuits of the board.
      Ill add a Bios request then to get further with it.
      Thank you sire
      • reformatt
        • Feb 2020
        • 1499
        So you said you had a donor board? Is it the same model? You can take a dump of the EEPROM from the donor and use that for this one. If it's an Intel board you'll need to clean the ME, but even with a dirty ME it should still boot with it, albeit a bit slower.
        If you have CPU Vcore, then you first check if it's the RAM slots that are the issue (check current with and without them inserted). I always cast a close eye over the pins of each slot first.
        • NanoPat
          • Jan 2023
          • 11
          Good morning.
          Thanks for ur reply. The donor is from an v15 ada. it uses the exact mobo thats why iam wondering that there are no schems for this sucker. Seems like its used for all 14 and 15 series. Sadly not possible to use the dump of it because the EEPROM I removed in the past, also a few mosfets are missing.
          Ill check the DIMM Slot then in next step. Good idea of course. Flashed a official rom which I got from a DC member just to see if something changes but no result. If it should post and create video output with that rom we can now clearly say that theres a chiplevel issue present
          • mkdj
            Lenovo IdeaPad 3 - Hard Disk not recognized in BIOS
            by mkdj
            Dear all,
            I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
            Here the steps I have taken to fix the laptop:
            - downloaded latest BIOS from Lenovo Website...
            10-18-2025, 03:43 AM
          • jendkkd jeje
            Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
            by jendkkd jeje
            So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
            I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
            10-11-2024, 03:12 PM
          • Loli Popu
            DELL 5590 LAPTOP DEAD AFTER BIOS WRONG FLASHED
            by Loli Popu
            Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
            12-13-2024, 03:28 AM
          • pirati
            by pirati
            10-27-2025, 04:20 PM
          • joven016
            Lenovo Ideapad S145 need working bios HELP!!
            by joven016
            Problem is blinking power led only
            i don't know exactly if it's s145-15igm or s145-14igm
            have a backup bios file but i dont know the serial.. coz text already erased at the back of the cover
            Mother board : fs440fs541 nm-c111 rev 1.0 2019-01-08
            Already tested some of posted bios here
            S145-14igm - success but invalid serial and not booting on OS
            S145-15igm - success with serial and some other info in bios but still not booting on OS
            already tried installing new windows but always booting on bios setup
            windows installer flash drive detected on...
            08-21-2025, 10:55 PM
