Asus UX550VD no power
  • koby058
    • Jan 2017
    • 373
    • israel
    I have this laptop MOBO, it has a short in the charging coil, shorted cap removed. now power is not entering the board.
    Measuring on the current sense resistor i have a fluctuating voltages.
    I can see 19 volt on the drain of the first dc-in mosfet but no gate present and voltage not passing.
    When i remove the second mosfet at the dc-in i got 24v on gate and 19 on source.
    but when i put a new second mosfet (donor board) getting same behavior .
    then i replaced the first mosfet as well but getting the same results
    19v vcc is present on bq24780s CMSRC not present, ACOK fluctuating 0 to 2.6v , no ACDRV
    Any thoughts that can help me?
  • mon2
    • Dec 2019
    • 14012
    Re: Asus UX550VD no power
    Remove the ~4k resistor on ACDRV pin and test again to see if the boosted ACDRV voltage returns.
    PS: Fauda new season on Netflix Doron (Lior) has still got it
    • koby058
      • Jan 2017
      • 373
      • israel
      thanks mon2, I will, and post tomorrow
      you know whats funny? the name of this asus laptop name is Doron
      Enjoy your fauda
      • koby058
        • Jan 2017
        • 373
        • israel
        well, i have kind of a problem, this 4k resistor is not near pin 4, and the trace is going to a via.
        also now, when i measure i am getting 0.75 steady on the current resistor and
        and ACDET is 2.6 stable.
        What do you think i can do ?
        • mon2
          • Dec 2019
          • 14012
          ACDET is perfect.
          How is the ACOK signal ? Also REGN ? REGN is instrumental to the ACDRV voltage.
          ACDRV voltage (should be ~25v) = adapter input + REGN voltage (~6 volts)
          Do not worry on the location of the 4k resistor - just find it -> flux it and remove it but do not lose it.
          The ACDRV voltage may be low due to the 2nd DCin mosfet being leaky.
          • koby058
            • Jan 2017
            • 373
            • israel
            Hi, REGN is 2.5v
            I cannot identify thv4k resistor
            • mon2
              • Dec 2019
              • 14012
              That is not a good voltage for REGN. This should be ~6 volts if this charger IC is working properly.
              Remove all power. Measure the resistance to ground for the REGN pin.
              • koby058
                • Jan 2017
                • 373
                • israel
                92 ohm
                • mon2
                  • Dec 2019
                  • 14012
                  Something is wrong here. Locate a capacitor that is often on this pin and remove it.
                  The resistance is too low (and we know from Star Trek that resistance is futile).
                  • koby058
                    • Jan 2017
                    • 373
                    • israel
                    I hav replased the charger ic, and now i have the 6v on regn but voltage is steal flactuating.
                    Now the resistance on regn is 27k ohm
                    • mon2
                      • Dec 2019
                      • 14012
                      Which voltage is fluctuating ? Is it ACDRV ?
                      Is the 4k resistor on ACDRV removed? It should be to confirm that ACDRV is stable without the connection to the DCin mosfets.
                      • koby058
                        • Jan 2017
                        • 373
                        • israel
                        I cannot fined it.
                        Both cmsrc and acdrv
                        • mon2
                          • Dec 2019
                          • 14012
                          ACDRV resistor - see attached. It is on the backside of the PCB.
                          Check the resistance and it should be ~4k ohms.
                          Then remove it but do not lose this part.
                          Then measure ACDRV voltage again to see if it is ~25 volts.
                          • koby058
                            • Jan 2017
                            • 373
                            • israel
                            I had to leave for today, i will update in the upcoming days, thanks a lot mon2
                            Can you please explain what the resistor is actually doing?
                            • mon2
                              • Dec 2019
                              • 14012
                              The resistor is stop ringing (bounce) of the ACDRV voltage.
                              A common fault is that the mosfet being driven by the ACDRV pin is leaking and causes this ACDRV voltage to sink to a lower value or even 0 volts.
                              Once you remove this series resistor, the mosfets will not be driven by their gate pins and no longer hinder the ACDRV voltage. Often, the ACDRV voltage will be normal.
                              Then you can focus on which mosfet is defective. As per above sticky by @Piernov, the 2nd mosfet is usually the bad seed.
                              Get Doron and his team to take it out. OT - did you know Lior was the real bodyguard for Arnold Schwarzenegger? He encouraged him to go into acting.
                              reference reading:
                              https://electronics.stackexchange.co...20interference.
                              • koby058
                                • Jan 2017
                                • 373
                                • israel
                                Thanks a lot mon,
                                Upon removing ACDRV, i see that ACDRV is not present, also CMSRC is not present
                                • koby058
                                  • Jan 2017
                                  • 373
                                  • israel
                                  Hi, I have removed the 4k resistor of ACDRV and i can see that ACDRV and CMSRC is missing, what do you think it could be ? charging port ? first mosfet ?
                                  • mon2
                                    • Dec 2019
                                    • 14012
                                    Start with, no power, meter in resistance mode -> measure the resistance to ground of the main power rail that follows the 2nd DCin mosfet.
                                    What is the resistance to ground ?
                                    Perhaps what is happening is that the main rail is shorted (bad cap?) and then this charger IC is not boosting the ACDRV voltage. That is, it turned ON ACDRV -> allowed for the voltage to pass through to the main rail -> sensed the excessive current draw due to a possible bad cap and then shuts down ACDRV.
                                    Post the resistance reading.
                                    Otherwise (Plan B..):
                                    Suggest to flux and reflow the replacement charger IC. Low air pressure but enough heat to make the IC swim in the liquid solder onto the pads.
                                    Under the conditions and shared voltages, this IC should be boosting the ACDRV voltage to ~25 volts. Leave the series resistor off the board so that the ACDRV pin is not loaded down.
                                    As long as REGN is ~6 volts, ACDRV should work.
                                    Recommended readings of the following Q&As raised with TI on this topic:
                                    https://e2e.ti.com/support/power-man...acdrv-question
                                    https://e2e.ti.com/support/power-man...-don-t-turn-on
                                    * read the comments from Wang5577 (3rd from the bottom)
                                    • shibu
                                      • Apr 2016
                                      • 28
                                      • uae
                                      actually how much voltage is getting on the fet gate ?
                                      • koby058
                                        • Jan 2017
                                        • 373
                                        • israel
                                        OK, i will check all of this tomorrow and post back
                                        ATM the resistor is out
                                          ASUS ZenBook UX550VD-BN011T Notebook Pro Specification for Upgrade or Repair
                                          This specification for the ASUS ZenBook UX550VD-BN011T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX550VD-BN011T boardview and UX550VD-BN011T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-06-2024, 06:08 AM
                                          ASUS ZenBook UX550VD-BN094T Notebook Pro Specification for Upgrade or Repair
                                          This specification for the ASUS ZenBook UX550VD-BN094T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX550VD-BN094T boardview and UX550VD-BN094T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-06-2024, 08:00 AM
                                          ASUS ZenBook UX550VD-BN010T Notebook Pro Specification for Upgrade or Repair
                                          This specification for the ASUS ZenBook UX550VD-BN010T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX550VD-BN010T boardview and UX550VD-BN010T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-06-2024, 06:34 AM
                                          ASUS ZenBook UX550VD-BO023T Notebook Pro Specification for Upgrade or Repair
                                          This specification for the ASUS ZenBook UX550VD-BO023T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX550VD-BO023T boardview and UX550VD-BO023T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-06-2024, 06:14 AM
                                          ASUS ZenBook UX550VD-BN032T Notebook Pro Specification for Upgrade or Repair
                                          This specification for the ASUS ZenBook UX550VD-BN032T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX550VD-BN032T boardview and UX550VD-BN032T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-06-2024, 06:11 AM
