Acer Aspire 5750_5755G NO DISPLAY
  • jeewantha
    • Nov 2016
    • 81
    • Sri Lanka
    MOTHER BOARD
    P5WE0 LA-6901P
    Rev2.0
    PROBLEM NO DISPLAY.
    I CHECKED ALL VOLTEGES .
    ONLY +VGFX_CORE NOT PRESENT.
    I CHANGED DRIVER IC, MOSFET, BUT STILL SAME.
    ANYONE CAN YOU HELP TO FIX THIS PROBLEM?
  • mon2
    • Dec 2019
    • 14103
    Re: Acer Aspire 5750_5755G NO DISPLAY
    Remove all power -> meter in resistance mode.
    Check the resistance to ground of this power rail that is not being enabled (+VGFX_CORE).
    What is the exact resistance?
    • piernov
      • Jan 2016
      • 4435
      • France
      https://logi.wiki/index.php/User:Pie..._I_solve_it.3F
      • jeewantha
        • Nov 2016
        • 81
        • Sri Lanka
        9.3 Ohms
        • G33RT
          • Oct 2016
          • 69
          • Belgium
          Any news on this repair ?
          I have exactly the same problem !
          ACER Board: Q5WV1 LA-7912P
          All voltages are present except +VGFX_CORE
          Controller chip is 95836H gives no output on UGATE1G and LGATE1G that drives both mosfets for +VGFX_CORE
          No shorts detected.
          Regards, Geert
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Sometimes bios flash solves it,sometimes replacing the PWM 95836 helps along with Both the mosfets. Sometimes its even the replacement of cpu that works. So no definite answers. be careful with the heat as this board's pcb doesnt take heat very well.
            • adhiea7x
              • Jun 2014
              • 7
              • 404 not found
              same case, How with this case? solved or not?
