Macbook Air A1466-No Display
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Logic Board#820-00165A
    Consumption on dc supply goes upto 590mA ,then drops to 390 and then again rise to 560mA with not much variation.(Using original magasafe2 65W cable)
    All the rails are present. No liquid spill or corrosion noticed under microscope.
    CPU_VCCST_PWRGD-Present
    ALL_SYS_PWRGD-present
    PLT_RST-Present
    R1540/41/42/43/44-33 Ohms
    Minor pulses on LPC lines with scope.
    Bios clean me flashed.
    Battery is charging. can be turned on/off with keyboard.
    What to check further? Any ideas are welcome.
    PS:Customer is going on a vacation-so 15 days time to solve the puzzle.
  • mon2
    • 14415
    Re: Macbook Air A1466-No Display
    What is the voltage to ground of PPBUS_G3H ?
    Measure at F7140 (both pins).
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      PPBUS_G3H is 8.62V measured on F7140-both pins.
      • mon2
        • 14415
        Check resistor R1275.
        Also here:
        https://logi.wiki/index.php/820-00165_Pulsing
        • reformatt
          • Feb 2020
          • 1432
          With no SSD present and just naked on the bench, these boards usually pull about 550 to 600ma, then settle to 350ma when they are trying to boot (e.g. USB ports are probed every 5 secs or so).
          Is there any SPI activity around U6100? Is the PCH/CPU at least trying to load code? I've seen other issues post BIOS load with bad HSIO or SPI to peripherals like audio etc in the U8005/Q1920 area.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Also here:
            R1275/R1270/R1280 are all ok.
            The link you gave is perhaps not applicable here as all rails are stable and not pulsing.
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              Yes, the consumption pattern mentioned here is only naked board with fan and dc-in board-no ssd/wifi etc.
              Yes, Spi activity is present on U6100.
              Q1920
              pin2-3.3V
              pin3-1.5V
              pin4-0V
              pin5-0V
              Q8060,pin4-HSIOFET_EN-0V
              Q8062,pin2-PCH_HSIO_PWR_EN-3.3V
              U8005-Working ok.
              PS:The fan goes to max speed after 30 seconds of power on.
              • dellxps15
                • Feb 2014
                • 1591
                • italy
                many board with all volt present (cpu 1,79volt present, cpu not getting hot)but no post on a1466 board got fixed by replacing u1950.
                • reformatt
                  • Feb 2020
                  • 1432
                  Ok, went back through my notes. The fault I found was a bad pullup resistor on the AUD_SPI_MOSI data line (R1663). This appeared to have caused the CPU to hang during the boot process. So check the data lines pullups/pulldowns as a sanity check (R1660~R1677).
                  Also check resistance of the PCH (when its at ambient temperature) at L7630. They usually read over 200 ohms, but anything 150 ohms generally indicates some kind of damage.
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    In this case, cpu is heating up. Still try replacing U1950??
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      R1660-R1673 all checked and resistance values are all ok. The ones which are pulled up by PP3V3_S0 are all 3.3V on both sides.
                      L7630 resistance is more then 200 Ohms.
                      • dellxps15
                        • Feb 2014
                        • 1591
                        • italy
                        did u try on external display ?
                        edit: about u1950 i almost replace it in all board because it's cheap and many time make macbooks work again.
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          Thursday was holiday for Indians as we celebrated our 74th Republic Day.
                          Will replace U1950 and see if it makes any difference.
                          • mcplslg123
                            • Jun 2015
                            • 7262
                            • india
                            Replaced U1950 but didnt helped. No changes in any signal/behaviour. I'm out of ideas for this particular case and may let it go unrepaired.
                            • dellxps15
                              • Feb 2014
                              • 1591
                              • italy
                              bad news...
                              did u try usb for activity ? or caps lock light if working or not when pressed ?
                              • mcplslg123
                                • Jun 2015
                                • 7262
                                • india
                                Caps lock light not working when pressed. There is activity on usb lines. I even see slight communication on LPC lines but the pulses were not usual. Anyway, i returned it to the customer UNREPAIRED. Perhaps someone more skilled and experienced may fix this unit.
