Re: Dell XPS 9550, Unknown Charger
Hi everyone, it appears that replacing PQ100 just fixed the problem. I didn't evaluate if I was actually still having issues after I replaced it because the multimeter reading didn't change, but it actually started working so, go figure.
Hi, I recently got an XPS 9550 that won't charge due to the "Unknown Charger" PSID issue.
I replaced PQ100 to no change, PR102 reads at 33 ohms, PR101 reads at 2.2k. When PQ100 is removed, the source pad reads at 3.3v, the gate reads at 5v, and the drain at 0v. When it is in place, both drain and source read at 1.4v, and gate still reads at 5v. PD100 is blown clean off and as such reads basically open.
I don't know what exactly to do from here, except maybe investigate PQ101.Leave a comment:
Yes, as suggested, test with another adapter.
The transient may have killed the MEC5085.
Remove all power. Meter in DIODE mode.
Red meter lead, yes red to ground.
Black meter lead to the MEC5085 pin used for the PD_ID communication.
What is the diode mode reading of the PS_ID pin?
PQ101 is a crowbar circuit that enables to disable the flow through mosfet if the adapter voltage is too high on the ps_id pin. The gate voltage of the mosfet is shorted to ground to disable it.Leave a comment:
did u try another original charger?Leave a comment:
I don't know what exactly to do from here, except maybe investigate PQ101.Tags: None
by motormayhemLaptop Question
I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when... -
by c.danielHello; so, i have this laptop; it came with battery charged only at 5%; when i plug in charger, led laptop is lightning white for 2 seconds, then it turn off and stay off.
In bios, health of battery is excellent; charger is unknown.
I test it with 3 dell oem chargers, all are ok.
Laptop in rest is working perfectly.
I upload schematics and picture with PS_ID flow; before PQ6 i have 3,1v, after PQ6 i have 3,6v. On pin 36 of UE1 i have also 3,6v.
Laptop came with charger socket kind of ripped off, center plastic was missing. I changed with a new one.
I suspect... -
This specification for the DELL XPS 9550 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 9550 boardview and 9550 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL XPS 9550 Notebook...09-06-2024, 07:11 AM
- Loading...
