Surface Pro 4 - cycling VCC_CORE, no VCCGT
  • Prott
    • May 2022
    • 154
    • Czechia
    I have a Microsoft Surface Pro 4 (i5, 8 GB) that originaly had a swollen battery and was crashing during Windows install. I replaced the SSD with a new one (from another surface) that had OS installed. As a result of this the Windows booted, but few seconds after the start it went into "Locking" screen and turned off.
    Now the "fun" starts:
    Upon removal of the motherboard from the case the fault changed:
    - When I start the tablet the VCCSA goes to 1.1 V for half a second and shuts off, followed by 1P2V_DUAL going to around 1 V and cutting of as well.
    - VCC_CORE also turns briefly to 0.8 V and then shuts off
    - VCCGT never shows any voltage
    - I checked the resistance to GND of VCCSA, VCC_CORE, VCCGT and all are the same as my working i5 Surface Pro 4.
    - There's no backlight, no picture, etc.
    My assumptions:
    - Based on the power on sequence it seems as if both VCC_CORE and VCCGT should be enabled by the same signal from the EC. It appears as if the EC shuts the power off because of some fault condition though.
    Ideally I would like to probe VRM_PWRGN, VCCST_PWRGD, PM_PCH_PWROK and SYS_PWROK to see when exactly the power on sequence stops, but so far I am not able to locate pads that correspond to those signals.
    Can anybody please offer any leads to what should I probe/test?
    Thanks a lot!
  • Stevedb
    Stevedb
    • Feb 2018
    • 624
    • Belgium
    Re: Surface Pro 4 - cycling VCC_CORE, no VCCGT
    Hi VCCGT has no voltage is no problem, this raail comes up when needed. Example when loading the windows. I would try to connect an external keyboard and see if you can toggle caps lock. If you can't then i would proceed on flashing bioschip.
    Regards Steve
    • Prott
      • May 2022
      • 154
      • Czechia
      Thank you so much Steve. Never realized the rail is only on at some point. You saved me a lot of troubles.
      In that case the problem is the power cycling - VCC_CORE, VCCSA and 1P2V_DUAL only has power for half (or so) seconds.
      Do you think this could be a bios issue?
      EDIT: If it is a bios issue, is there any other way to program it without desoldering it from the board? I have a CH341 programmer with 1.8V module, but no way of attaching it to those smd pads around the chip. Should I solder wires from the chip to the programmer? Thank you again!
      • Prott
        • May 2022
        • 154
        • Czechia
        UPDATE: It was a faulty BIOS chip - upon replacing it with a good one the Surface boots and works. Thanks again Steve!
        • Stevedb
          Stevedb
          • Feb 2018
          • 624
          • Belgium
          No problem I was happy i could help you.
          • Prott
            • May 2022
            • 154
            • Czechia
            I am kinda still stuck at the ME cleaning procedure (looks like the UEFI can't communicate with ME), but I will do that today. For now I am just happy the Surface posts again
            • Stevedb
              Stevedb
              • Feb 2018
              • 624
              • Belgium
              you can always ask somebody do for you an clean me region in bios section if you make a request in bios section. Good luck Steve
              • Prott
                • May 2022
                • 154
                • Czechia
                I managed. The problem was that, for some reason, I expected the bios chip to be a 1.8V part while in fact it's 3.3V (thus I got a ton of corrupted bios images). Now it works like a charm.
                • Stevedb
                  Stevedb
                  • Feb 2018
                  • 624
                  • Belgium
                  Good work man 👍
