Dell Precision 3510 GPU Issue
  • s_henya
    • Jan 2011
    • 483
    • Israel
    Hi guys,
    Im troubleshooting this nice laptop i7-6820HQ with Dual GPU.
    Intel HD Graphics 530\ AMD FirePro W5130M 2GB GDDR5
    Laptop is working normally up until the AMD driver gets installed.
    Then windows 10 is failing to boot.
    I tried BIOS update from DELL website, and fresh windows installation. Manual driver installation from AMD website\ Dell website.
    Googling around it seems like a common issue with the driver or the GPU itself.
    is there any way to disable this GPU?
    Has anyone encountered this and managed to find a solution?
    Its a nice laptop to scrap...
  • Vspeed
    • May 2022
    • 53
    • Portugal
    Re: Dell Precision 3510 GPU Issue
    You have a defective GPU. The only solution to it is to replace it with a re-balling machine.
    I had a different laptop with the same issue.
    One workaround is to remove the mosfets and coils going to the GPU. This way, the GPU is not detected anymore.
    • s_henya
      • Jan 2011
      • 483
      • Israel
      Hi it is possible that the problem is within the gpu
      But the thing is the Dell diagnostics shows everything is good.
      So it could be a driver problem.
      As for the motherboard modifications to disable the amd gpu.
      I need very specific components that supposed to be modified.
      I don't want to remove parts and end up with an unusable board.
      • s_henya
        • Jan 2011
        • 483
        • Israel
        Hi any advices on how to disable the AMD GPU?
        i can try to reflow the chip and see if it helps even for a short time to understand if its a driver issue or a chip issue.
        please give me your inputs.
        • Sephir0th
          • Oct 2020
          • 1289
          This isn't a stone-old nvidia GPU with "bump-gate" issue. Heating or "reflowing" the BGA won't do anything except more damage.
          Also, regarding the previous Suggestion to remove the coils/mosfets: Usually that's not enough to disable the GPU and make UMA conversion. It depends on the board Design, but often you have to do dozens of charged to the circuit.
          Your best chance is to deactivate the GPU in device manager before driver getting installed.
          FairRepair on YouTube
          • s_henya
            • Jan 2011
            • 483
            • Israel
            So my only option is motherboard replacement?����*♂️
            I wonder how no one ever thought about a solution for this model so far…
            • Sephir0th
              • Oct 2020
              • 1289
              You mean by manufacturer? Well, this would play against the planned obsolescence...
              • s_henya
                • Jan 2011
                • 483
                • Israel
                I hold alot of respect for the experts here, but yeah a solution should have been given by Dell.
                Maybe they listed something in the schematics on how to disable the AMD GPU
                • huyPhuongels
                  • Dec 2015
                  • Viet Nam
                  Hello s_henya,
                  I’m experiencing the same issue as you. Are you working on hardware repair as well? Could you share if you have already found a solution?
                  I suspect that the problem might be due to the power filter capacitors on the mainboard aging. My current plan is to replace them step by step in different areas and verify if the issue improves.
                  Do you have any insights or suggestions on this approach?
                  Thank you!
                  • nova100
                    laptop dell precision 3510 .issue of MEC5085
                    by nova100
                    I have a laptop dell precision 3510
                    bord id:ADP80 LA-C841P
                    REV 3.0
                    19-11-2015
                    GPU AMD
                    MEC5085-LZY
                    The laptop was working fine until I flashed the MEC5085-LZY
                    Of course I took a bakup from it.
                    Now the laptop cannot recognize the battery and tells me that this is not a Dell battery on the BIOS page and there is a continuous flashing of the battery charging light.Of course, a message appeared to me that there was a problem with the serves tag, and I entered it as it was printed on the laptop cover.
                    I said there might be a problem...
                    10-29-2023, 01:36 PM
                  • Ven
                    Dell Latitude 3510 Overheating & Fan Control Issue – Need Help
                    by Ven
                    Dell Latitude 3510 (Intel Core i7-10510U) CPU Overheating
                    Issue Description:
                    1. CPU Overheating to 100°C
                      • When I start the laptop from a cold state, it takes about a minute to reach temps around 80-90-100°C, and CPU thermal throttling triggers.​
                      • When the CPU fan is running at full speed (by disconnecting PWM and TACH cables), CPU temperature stays around 50-60°C.
                      • However, when the fan is connected normally to the motherboard, it does not kick in at high temperatures.
                      • I also noticed a few times that the fan kicked in for a very short time, but it does not stay on consistently.
                      • Thermal
                    02-12-2025, 03:57 PM
                    DELL Precision 5820 Precision 5000 W-2125 Specification for Upgrade or Repair
                    This specification for the DELL Precision 5820 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Precision 5820 boardview and Precision 5820 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                    09-12-2024, 03:44 PM
                    DELL Precision 3630 Precision i7-9700 Specification for Upgrade or Repair
                    This specification for the DELL Precision 3630 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Precision 3630 boardview and Precision 3630 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                    DELL Precision 3640 Precision 3000 i7-10700K Specification for Upgrade or Repair
                    This specification for the DELL Precision 3640 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Precision 3640 boardview and Precision 3640 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
