macbook pro 820-2914-A - no image / no backlight
  • cruiser_
    • Nov 2019
    • 124
    • Ireland
    hi,
    i am working on this macbook pro that had amd gpu shorted.
    it now chimes and boots but there is no backlight.
    Can't see an image with a flashlight either...
    I tracked it down to:
    - No LCD_PWR_EN - u9600 enables
    - No LCD_BKLT_EN - u9600 enables
    - No EG_BKLT_EN from
    - No EG_LCD_PWR_EN
    I forced EG* signals to 3.3V but am still not getting signals from U9600.
    U9600 has all three power inputs (PP3V3_S0, PP1V8_S0, PP1V2_S0).
    LCD_PWR_EN is not pulled down by Q9607 (GMUX_S3_PD_GND above 2V).
    what does the gmux chip need to output LCD_*EN signals?
    what else to check before I go forcing these?
  • Ugur87
    MacBook Air M4 A3240 Brand New Water Damage no Image
    by Ugur87
    I have a brand new 13.6-inch MacBook Air M4 that was only used for three days and now has water damage. A glass of water was spilled over it. I examined the motherboard and there was only water next to the display connector. I cleaned it with isopropanol and the components look clean. The MacBook obviously turns on and draws 20 volts from the power supply. The keyboard backlight comes on, but the display remains black. Where should I best start? Even when I shine a light on the display, I don't see any image. I have all the tools I need, including an infrared camera. Where should I best start?...
    08-28-2025, 01:09 PM
  • baglaivlad
    MacBook Pro A2289 (820-01987-A) No boot/image, but boots to DFU
    by baglaivlad
    Hi everyone. Just a reminder I am not a professional repair technician, fixing Apple electronics is my hobby.
    Recently got my hands on MacBook Pro A2289 with interesting behavior. Pristine condition, no water damage, no visual issues whatsoever. It has no image, no CapsLock, no life except the fan is spinning. But it is able to boot into DFU and recognized by another MacBook. I tried to revive and restore the laptop, but the process ends when the MacBook usually should show an Apple logo with a progress bar. I assume the main power lines and T2 are working. It seems like the Intel...
    01-09-2024, 09:55 PM
  • thuygsm
    Macbook pro A2159 EMC3301 no image, no CapsLocklight, only USB activity
    by thuygsm
    Hello! Please help with a strange disease that I have never encountered before.
    At first I got the following status:
    MacBook does not turn on. Current consumption is about 0.500-0.600A at 20V from USB-C.
    - no signs of rust, or spilled water
    - CPU gets hot, fan still spins, no Capslocks light
    then I cleaned it and I got the following video:
    - Cannot install software, and after a while I get a red screen and the whole thing freezes
    Macbook Pro A2159 / Bệnh lạ
    07-28-2025, 11:35 AM
  • Madoy104
    Macbook Pro A1989 - No image, working fine with external monitor
    by Madoy104
    I have a MacBook Pro A1989 that was likely exposed to liquid. It doesn't display an image on the built-in screen, but the screen is backlit (you can't see the Apple logo or any other elements when held up to light). The laptop provides 20V and 1.5-2A, and it works fine when I use it with an external monitor. Currently, the connector for the display (J8500) is disconnected. I'm writing to ask for help in diagnosing the issue. I've heard that when the J8500 is exposed to liquid, the processor pin responsible for the display might short-circuit, and I'd like to know...
    08-15-2024, 10:01 AM
  • envym
    by envym
    Hi everyone!
    06-27-2025, 08:54 AM
