PORSCHE 928 Resistor Pack - Need Help
    • 30979
    Re: PORSCHE 928 Resistor Pack - Need Help
    if it's for the blower then fuck it, fit a chinese pwm motor speed controller and replace the switch with a pot.
    i have seen and fixed this problem half a dozen times now on ford vans - they are notorious for burning up resistors on the blower.
      • Jul 2011
      • 6033
      I would second this idea as long as it only for the ac fan blower motor
      You would have better fan motor speed control but I would modify the speed controller for a minimum speed so you do not have the fan speed to low because if the refrigerant control device is a cap tube restricting device you will have to do this because you will freeze up the evaporator coil if it is a TXV valve or a expansion control valve this is not so important but you still will have to have a minimum amount of air flow
      Now if you had a temperature controller that included a PWM controller function that would be the best of both worlds because you base the fan minimum speed on temperature
      • redwire
        • 3906
        What sort of PWM controller were you thinking of? Most of them are pretty ugly i.e. this one has three heatsinks when all you need is one. It looks like Darlington instead of a mosfet lol and 5V 7805 for the 555. Then you need a box, then you gotta move the pot etc or make it compatible with the old 0-1-2-3 speed switch. For a classic car it would be a bit of work, but worth it.
        Getting cabin temp is actually hard to to do, where do you put the thermistor? I've seen it usually top back of the front seats, or rear-view mirror.
          • 30979
          the controller i'v seen is cased in a perforated case, but it could look similar to that inside i suppose.
          • brispuss
            Ryobi 36V (aka 40V) 6Ah Faulty Battery Pack
            by brispuss
            Purchased a Ryobi 36V 6Ah battery pack maybe just over a year ago.
            Battery pack had been used on about 3 or 4 occasions for powering a cordless lawnmower. I was wanting to use this battery pack again recently, but on checking the battery charge state via the battery pack test button, there was no LED indication at all of charge state which suggested the pack was fully discharged.
            I found this to be odd as I usually fully recharge battery packs shortly after use. So either the pack developed some sort of fault which completely discharged the pack cells (after recharging),...
            12-28-2022, 02:58 AM
            HP EliteBook 840 G5 + LaCie Porsche Design USB 3.0 1TB Mobile Drive Notebook 800 Specification for Upgrade or Repair
            This specification for the HP EliteBook 840 G5 + LaCie Porsche Design USB 3.0 1TB Mobile Drive Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G5 + LaCie Porsche Design USB 3.0 1TB Mobile Drive boardview and 840 G5 + LaCie Porsche Design USB 3.0 1TB Mobile Drive schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users...
            09-06-2024, 08:50 AM
            HP EliteBook 840 G5 HC + LaCie Porsche Design USB 3.0 1TB Mobile Drive Notebook 800 Specification for Upgrade or Repair
            This specification for the HP EliteBook 840 G5 HC + LaCie Porsche Design USB 3.0 1TB Mobile Drive Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G5 HC + LaCie Porsche Design USB 3.0 1TB Mobile Drive boardview and 840 G5 HC + LaCie Porsche Design USB 3.0 1TB Mobile Drive schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
            HP EliteBook 850 G5 + LaCie Porsche Design USB 3.0 1TB Mobile Drive Notebook 800 Specification for Upgrade or Repair
            This specification for the HP EliteBook 850 G5 + LaCie Porsche Design USB 3.0 1TB Mobile Drive Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 850 G5 + LaCie Porsche Design USB 3.0 1TB Mobile Drive boardview and 850 G5 + LaCie Porsche Design USB 3.0 1TB Mobile Drive schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users...
