Component id asus ac3100 rt-ac88u
  • m4a2t0t
    • Mar 2013
    • 276
    Have this router that was damaged by lighting and it appears to have come from the modem through the WAN port.
    I have 1 blown on the top and 1 on the bottom. Im guessing they are all the same values. Do you think that's a safe assumption? What type of SMDs are those 2 sets of SMDs next to each other? I can see arching and they all test 0L.
    Thanks for any help
  • petehall347
    • Jan 2015
    • 4426
    Re: Component id asus ac3100 rt-ac88u
    cant see your pictures .
    • m4a2t0t
      • Mar 2013
      • 276
      Forgot to click upload
        • 31009
        ceramic capacitors.
        probably not the *real* issue, if that happened then you need to check the transformer windings and whatever connects to the other side of it!
        • m4a2t0t
          • Mar 2013
          • 276
          2 of the transformers have open windings. I did check all the filters connected to the transformers and they are ok. After the filters they connect to either a Broadcom BGA or a Realtek IC.
          The caps measure 1080 pF.
          The 2 transformers are labeled
          1642
          HN18101DG
          1644
          HN8011VG
          I cant find any spec sheets. All I have been able to figure out is its a Mingtek product but their site is worthless. I did find one on alibaba but the first number (1644) was different and they were like $20 each. Worldway seems to have some but their MOQ is like 1k-2k
          Any suggestions for comparable products?
