Agilent DSO-X 2012A no power repair
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8810
    Well, my trusted Agilent DSO-X 2012A quit on me this morning after an hour of work. Darrn... in the middle of something of course.
    Called Agilent Tech Support and they were awesome in helping me to find a new one (Thanks bud R.R.!).
    Anyway... since that bean is already bad, why not open it and see if I can fix it? Sorry no pics this time around. However here is the fix:
    * Fuse F1 blown 250V 6.3V mini
    * Main filter capacitor dead short and hot as @#$%^! 420V 100uF
    Took the main filter cap out, checked for other shorts or opens on the PSU and I didn't find any. Replaced the fuse and the main filter cap with parts out of my bin and all is O.k.
    Happy ending at least. Back to work.
    Cost: Zero $$$
    • 31936
    Re: Agilent DSO-X 2012A no power repair
    so what shit cap was it?
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8810
      I should have figured that you would want to know...
      It was a Nichicon GU(M) series, 105C rated. 420V, 100uF
      Visually it is looking normal, maybe a slight bulge on the top if light shines on it. However it has a dead short like 0.2 Ohm.
      I replaced it with a 400V, 120uF cap I had... and the fuse too... Works fine as kind!
      The PSU has a PFC built in. Does 12V at like 10 amps or so. Look at the attachment.
        • 31936
        hang on, why does a scope need 12v at 10A??
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8810
          Good question. Apparently the PSU only has one output and that is 12V and it can do 10 amps. I don't know why that ole scope needs that kind of power, but it does have a few extra things like a generator.
            • 31936
            too bad it has pfc.
            the rigol and siglent dont.
            this means you can run them on dc from battery packs
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8810
              yeah... the Siglent is very nice for the money. Mine is getting old now, but still works good... well... as long as the caps don't short out...
              • Albean
                [REQUEST] SPI Dump for Samsung UN40D5003 / Main BN94-05416C
                by Albean
                I'm working on a dead Samsung UN40D5003BG. There is no standby LED and the TV is completely unresponsive.
                Here are the TV details:
                • Model: Samsung UN40D5003BG
                • Main Board: BN94-05416C (PCB code: BN41-01714B)
                • Panel: LD400BGD-V2
                • SPI Flash Chip: Winbond 25X40BVSIG (IC1302)
                Troubleshooting done so far:
                1. Disconnected the Main Board from the Power Supply: Backlights turn on immediately. PSU seems fully operational.
                2. Reconnected everything and measured voltages on the Main Board:
                  • 5.3V Standby from PSU is present and stable.
                  • 3.3V on LDO regulator
                03-17-2026, 04:00 PM
              • nickgronk
                64PN5500 | BN44-00618A Main fuse keeps popping
                by nickgronk
                Power supply board BN44-00618A keeps blowing main fuse and nothing plugged in to it.
                I was gifted a 64PN5500AF, picture was amazing, but tv smelled like cigarettes and was dusty AF. I opened it up, blew all the dust out of it, removed PSB & main, and cleaned the metal underneath. Also blew all the dust off all other boards. Put the power supply back in, then mainboard. Soon as I turned it on there was a "pop".
                The main fuse (T12AH250V) blew
                I removed the power supply to be sure nothing underneath, all good. Soldered on a t12ah250v fuse and sure enough it popped...
                01-22-2022, 10:43 PM
              • cheeky2
                by cheeky2
                05-25-2024, 03:27 AM
              • Rider07
                Generic 500W ATX Power Supply (UC3842 PWM) - Schematic Request & No Power Issue
                by Rider07
                I am working on a generic 500W ATX Power Supply unit and I am looking for a schematic diagram or service manual to help trace a power issue.
                Board & Component Details:
                • Device Type: ATX Power Supply
                • Main PWM Controller: UC3842 / UC3843 IC
                • Primary Switching Transistors: MJE13009 / N-Channel Power MOSFET
                • Output Rectifiers: MBR20100 / STPS3045
                Symptom / Problem: The unit is completely dead with no power output. The main fuse was blown when I first opened it.
                Troubleshooting Done So Far:
                • Replaced the blown main fuse.
                • Checked
                08-27-2026, 05:16 AM
              • Dani_2024
                by Dani_2024
                10-28-2024, 05:06 PM
