Quick 70gw+
  • Sanjeewait
    • Aug 2016
    • 63
    • Sri Lanka
    Quick 70gw+
    I have a QUICK 70GW+ SMD rework station. it hot air gun not working, blower on but heat gun not working, display see heat 35 not up to going heat. any one help me.
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3622
    • slovakia
    Re: Quick 70gw+
    check continuity on heating element
      • Jul 2011
      • 6067
      Re: Quick 70gw+
      Also check either a for a relay if it has one or triac or mosfet or something else that would control the heating element if it has a optic sensor check that the input side is getting a signal to turn on if you have a signal on the input then check output for power
      Check wiring going to the element also check and see if it has a thermal fuse or not
      • flysky
        Gigabyte H610M S2H V2 help to identify the element.
        by flysky
        There is a motherboard Gigabyte H610M S2H V2 (DDR5), I can't find boardview
        Help to identify the element, marking on the element - C31PH. It stands next to the USB 3.0 and it looks like it is ESD Protect chip. We need a datasheet to this element. Maybe someone has already identified such an element. Help please.​
        01-23-2025, 07:21 PM
      • CuriousJohn
        Burco boiler power problem
        by CuriousJohn
        Burco BCPLSAFWM5L 5 Litre Wall Mounted Automatic Water Boiler With Filtration UK 240v
        Does anybody have any experience with these Burco units at all there is no record of them on the forum lol and a proper service manual would be nice. I invite you all to pesuade me not to botch repair it with a 5v relay, read on.
        This unit was rescued from a skip 3 years ago, the only fault it had then was no backight display (plus it wanted a new probe set and top seal) but the screen was never an issue you can still see the screen as is and I just use it to get 5 Litres of very hot...
        12-22-2024, 10:25 AM
      • EasyGoing1
        The best way to drive a heating element?
        by EasyGoing1
        I've got this circuit that I've been playing with on a breadboard. I'm not happy with it mainly because the MOSFET gets too hot and generally controlling the temp of the heating element with the Arduino has proven to be a little more cumbersome than I would like.
        What I would like to know, is what is the best way to set up a circuit like this? The heating element is just a PCB and its going to be mounted under a 3D-printed enclosure that a lizard will use to warm his belly.
        This is the general setup that I have now.
        This is what the...
        01-25-2023, 11:29 AM
        Mounting and Handling Guidelines for TO220 TO220F TO247 Cases / Packages
        The TO220, TO220F and TO247 are the popular packages for power devices because of their versatility and ability to dissipate moderate amounts of heat. This application note describes the basic guidelines for handling power MOSFETs in TO220, TO220 and TO247 packages shown in Figure 1. Please note that only mechanical and soldering guidelines are covered here. Additional precautions are required for isolating high voltage rated devices to meet safety regulations.
        Securing a good thermal interface between...
        10-07-2024, 04:35 AM
      • petemanuk
        Help with IR6500 rework station
        by petemanuk
        I been playing with a recently acquired IR6500 rework station and watching lots of YouTube tutorials to see how to use it with not much success. I’ve only recently joined badcaps but going through the forums there is a lot of knowledge here, so though it best is if I ask my question here.
        1. Firstly is the IR6500 any good for BGA rework or should I be spending my money on a better one.
        2. The instruction manual is pretty useless on explaining how to set the PID loops (no information at all!!) both top and bottom heater for th Kp, Ki and Kd...
        10-14-2022, 12:31 AM
