Another individual or tech horribly replaced the HDMI port. Customer pushed the whole inner wafer in knocking out three components. I have the diodes already in stock and have replaced hundreds of these ports. Can you label component that's identified by 16? I assume it's the same as the one directly below it. This is for CUH-1115A which probably the same as CUH-1005A.
Identify PS4 HDMI SMD
Re: Identify PS4 HDMI SMD
Likely just a pull up resistor.
Did you by any chance check the resistance of that location when you grabbed it from a BLOD system?-Thomas
I'm a hardware engineer focused on networking equipment for my day job. I void warranties and fix consumer electronics for fun.
Cool. Just to follow up --- is the console good to go then? Did you fix it?
Looking at the HDMI pinout and assuming the color coding is correct. This is pin 16 -- the DDC Data -- it's an I2C bus dataline. The drivers are ope-drain and need a pull up to function.-Thomas
The two light blue/gray resistors on a CUH-1115A have the following attributes:
2k ohms
1 x 0.5mm or 0402 (1005 metric)
Height: 0.35mm
Power: either 1/16W or 1/10W, higher probably better
I've replaced several zener diodes with P/N VDZT2R5.6B on PS4s, and they've always worked. They're close to the port on the CUH-1215A model, and sometimes customers push the ports inward knocking off the diode. Saw two diodes blow along with an HDMI encoder IC once.
Hello everyone
I posted a new topic, I have almost the same concernLast edited by Christian0734; 11-15-2020, 03:46 PM.
Can anyone tell me what the resistor or capacitor is label 18 in this image? I've seen it described as a resistor and others say it's a capacitor. I am repairing a board for a friend that it was missing. So I don't have a donor board to look it up or transfer it from.
Originally posted by Mechengr103 View PostCan anyone tell me what the resistor or capacitor is label 18 in this image? I've seen it described as a resistor and others say it's a capacitor. I am repairing a board for a friend that it was missing. So I don't have a donor board to look it up or transfer it from.
