replacement for a transformer found in an old camera
  • Alimash
    • Jul 2019
    • 31
    • Lebanon
    Hello friends
    I am trying to fix my old camera "samsung s860" after it took a dump in water, the PCB also took a shock
    i successfully clean it and turn it back on but the shock cause a small transformer (i think) next to the flash capacitor to pop out of the board which broke one of the winding.
    my problem is i couldn't find a replacement on the net whatever i searched for,the only code written is "91K" and some unread code in the bottomn of the component.
    I need a replacement for this component for the flash to work.
  • SistMaticZ
    • Jul 2019
    • 72
    • Morocco
    Re: replacement for a transformer found in an old camera
    see if you can get the broken wire out ot at least it shows up in order to solder a wire to it.
    • redwire
      • 3910
      Camera photoflash transformers are custom parts, I've never seen them for sale. They are very tiny. Another Samsung camera might use the same part.
      • Alimash
        • Jul 2019
        • 31
        • Lebanon
        I already tried that :-)
        • Alimash
          • Jul 2019
          • 31
          • Lebanon
          Ok thanks
          I will look into that
          • truclacicr
            • Apr 2019
            • 321
            • australia
            Service manual:
            • redwire
              • 3910
              The photoflash HV transformer is Samsung W05-243 transformer p/n AD26-00033A. There is also the trigger transformer KP-133.
              The IC can use:
              TDK LDT565630T-002
              Tokyo Coil Engineering T-16-024A
              Asatech ST-532517A
              Not sure if one of these matches the original.
