Wacom Cintiq 13HD Touch Display
  • reddemonic
    • Jun 2015
    • 42
    power up, but display get static effect and no signal. when i open up i found this ic is burnt.
    could be a mosfet that require for HDMI signal to work.
    i can see letter "H". multimeter read 0v on all pin. this ic is probably shorted.
    no schematic available.
    do i need to buy a working one, just to see the ic Markings?
    • Jul 2011
    • 6046
    Re: Wacom Cintiq 13HD Touch Display
    Just for the fun of it I looked on EBay for this
    These things are not cheep
    But I did find some used ones but even with that they are not cheep either
    To buy a used one maybe the way to go unless someone on this forum has one and would not mind taking there’s apart to see what the part number is
    Or look what that IC chip is next to and maybe you can figure out what it might be
    • reddemonic
      • Jun 2015
      • 42
      hi Sam, i've managed to buy a working Wacom Cintiq 13HD display from eBay.
      i've taken a photo of this mosfet.
      i cant find "C163H" on google. the chip next to it is "24C02WP"
        • 31094
        i dont see any photo's - upload them.
        • reddemonic
          • Jun 2015
          • 42
          they are there, maybe you have imgur.com blocked.
          i've uploaded here, thanks
          known working board:
          • reddemonic
            • Jun 2015
            • 42
            bad board:
              • 31094
              well it is probably a reset chip or voltage regulator, and may be from RichTech
              • reddemonic
                • Jun 2015
                • 42
                24C02WP is a eeprom chip, if the chip is bad then i'll need to make a dump from the good working board.
                • reddemonic
                  • Jun 2015
                  • 42
                  very similar to this chip's design
                  https://cdn.badcaps-static.com/pdfs/...0d42bddc06.pdf
                  • reddemonic
                    • Jun 2015
                    • 42
                    i've found it, if any1 want to know.
                    https://www.aliexpress.com/item/ESD-...689495708.html
