PS5 ON but no display
  • Reticula
    • Jan 2024
    • Mรฉxico
    Hi everyone, I have a PS5 with image problem.
    I have changed filters, HDMI port, 100 nF cap, Zenner diode, TPS2552D voltage regulator, there are no shorts between pins and there is continuity to their respective lines...
    I made the diode scale measurements on each PIN based on an internet image and the values vary from 10-30 ohms to the referred value, the same in the IC the values vary from 10-30 ohms.
    But it still doesn't give an image, the TV recognizes the console as "PS5 game console" but that's it.
    I have already tried two different TVs and two HDMI cables that do work. I honestly don't think it's the IC, if you have any other ideas I would greatly appreciate it.๐Ÿ˜•๐Ÿ˜•โ€‹
  • reset1986
    • Dec 2014
    • 308
    • italia
    HDMI like on PS4 there should be a protection fuse
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8352
      Wrong assumption. Only because the PS5 identifies properly on the TV, doesnโ€™t mean you get a picture.
      • reset1986
        • Dec 2014
        • 308
        • italia
        check the filters if they are working, last encoder change
        โ€‹
