I need file to flash with gigabyte b450m s2h ch-341a
  • Yakubusta
    • Nov 2022
    • 19
    • Türkiye
    Hello friends. I bought a new AMD RYZEN 5600 CPU for my motherboard. normally it had 2600 installed on it. I installed the new processor directly without updating the bios and when I turn on the computer, it works, the fans are spinning, but there is no image.
    While researching what I can do, I decided to flash the bios integrated with CH341, but I guess it didn't work with the bios I downloaded from the site. I backed up the original software and when I checked it, there are FF spaces in between. Do you guys have a solid bios software or do you have a chance to help me somehow. original bios is attached.
    MOTHERBOARD: GIGABYTE B450M S2H
    Flash program I use: AS PROGRAMMER
    DEVICE: CH341A
    M_BIOS INTEGRATED : MX25U12873F
    • 21841
    Re: I need file to flash with gigabyte b450m s2h ch-341a
    https://www.gigabyte.com/Motherboard...upport-dl-bios
    Ty different versions.Put the old CPU back in if you have it,starting with the oldest update the bios incrememntaly
    • Yakubusta
      • Nov 2022
      • 19
      • Türkiye
      Unfortunately, there is no image on the screen. I need the image to update the bios
        • 21841
        You have a ch341a programmer. If you mean a bios image they are all available at gigabyte support. The file extension names are not .bin ,just rename the file for example B450MS2H.63d -> B450MS2H.bin . The file size is 16,384MB .
        • Yakubusta
          • Nov 2022
          • 19
          • Türkiye
          I tried, but it still didn't work. There is a lot of difference between the original file I backed up and the file I downloaded from the site.
          • hoaca388
            Badcaps
            • Jan 2022
            • 12317
            Of course, because your backup file is just a junk file, this error is mainly due to CH341A not working correctly, so when it writes it is also incorrect. What your bios chip received is just garbage so the main board can't work.
            • Yakubusta
              • Nov 2022
              • 19
              • Türkiye
              Well can you show me a way how to fix it. I can get whatever I need as equipment
              • hoaca388
                Badcaps
                • Jan 2022
                • 12317
                There are many support software for CH341A such as NeoProgrammer, Colibri, AsProgrammer, Flashrom… Try changing them.
                • lotas
                  • Jan 2016
                  • 4784
                  • Russia
                  Do not forget that this NOR Flash (MX25U12873F) is powered by 1.8v, you need an adapter for CH341A (3.3v - 1.8v)
                  • Yakubusta
                    • Nov 2022
                    • 19
                    • Türkiye
                    [QUOTE=lotas;1188038]Do not forget that this NOR Flash (MX25U12873F) is powered by 1.8v, you need an adapter for CH341A (3.3v - 1.8v)[/QUOTEI
                    I know but I still took the risk and threw the software but it still didn't work. The software I downloaded from the site has a lot of FF at first and in between. I thought that the software is not suitable for the Ch341A model.
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 12317
                      [QUOTE=Yakubusta;1188047]
                      No, file from Gigabyte site's a virgin bios. It's ok.It has nothing to do with which programmer you use.
                      • yvzasl
                        • Feb 2022
                        • 16
                        • Türkiye
                        Thanks for information
                        • DIA BED
                          • Feb 2025
                          • Algérie
                          I need image bios to gor b450m s2h pls
                            SMDFlea commented
                            Editing a comment
                            Read posts 2 and 4
