Dell optiplex 3000 micro bios
    Re: Dell Optiplex 3000 Micro Bios needed
    Problem: Absolute enable/ need to disable
    Board i12 ADL 6L
    202040-1
    D10NK$CA
    rev: A00
    service tag: 532MXR3
    Flash this to 32mb chips , put back 16mb chip, giv feddback enjoy!!!
      thank you, it works
        Re: Dell optiplex 3000 micro bios
        Please help, please remove password and disable absolute. Thanks.
        Service tag: BQ7WFT3
          please help me, thank you.
            put back 32Mb as is and write only 16Mb
            all donations are welcome,
              Thank you.
              Password has been removed, but absoluted has not. No problem, with Dell's bios, absoluted can be turned off if you use windows for 3 days.
                any solution for dell optiplex 3000 micro pc
                two bioses
                gigadevice 25b128esig
                gigadevice 25R256eyig
                wich to reprogram
                locked bios ..
                thanks in advance
                  two bioses
                  wich to reprogram
                  locked bios ..
                  thanks in advance
                  Both
                  Become a Badcaps supporter
                  Thanks to all supporters.
                    Where to download unlocked bios. Or can i unlock mine
                      You can unlock yours.
                      https://www.badcaps.net/forum/showthread.php?t=103569
                        I have the same problem with my Dell... Can anyone help me with the password or bios update
                        Can someone make me new bios bin for dell 3000 mini pc
                        SN: GSZ W7T3
                        Unit is blinking 3 amber and 6 white it could be bios corrupted
                        NOw is ok, il change 32MB file...
                          Hi. pls help me remove admin password
                          service tag: 42127V3
                          thank you
                            RA Dell optiplex 3000 Please remove the password Service tag is G0GKBT3
                              Thank you for checking I have read the bios files again. This time I believe its
                              correct, please see the attachment.
                              FYI if anyone is struggling to read MX77L25650F
                              I used CH341A
                              I had to add the chip to the database of the CH341A Programmer V1.03 by adding the line in the chiplist file.
                              <MX77L25650F id="C27519" page="256" size="33554432"/>
                              Hope this info is useful for anyone with the same chip.
                              Hi what connector did you use? sop16 to dip8?
                                Unlocked
                                  SN: GSZ W7T3
                                  aaa
                                    Originally posted by hoaca388 View Post
                                    Unlocked
                                    Thank you very much
                                      Can someone help me remove the password and absolute computrance of this bios. Thank you.
                                      ST: GKLFXW3
                                        I just picked up a Optiplex 3000 Micro and it has the Absolute feature enabled. I want to permanently disable this option. I plan to dump both BIOS chips today, and I can post the files to have someone do the work for me. However, I would also like to learn how to make the changes myself. Are there any resources or tutorials specific to Optiplex Micro or Dell BIOSes that someone can point me towards? Also, I just wanted to confirm that I need to dump the 25B128ESIG (16mb) and 25R256EYIG (32mb) chips. Thanks!
