Need HP Prodesk 600 G6 Desktop Bios dump
  • beast4ever
    • Feb 2015
    • 153
    • egypt
  • hoaca388
    Badcaps
    • Jan 2022
    • 11224
    • Viet Nam
    Re: Need HP Prodesk 600 G6 Desktop Bios dump
    HP ProDesk 600 G6 PCI Microtower PC (9CV80AV)
    • beast4ever
      • Feb 2015
      • 153
      • egypt
      does not work
      • hoaca388
        Badcaps
        • Jan 2022
        • 11224
        • Viet Nam
        Check back your hardware.
        • jimflan
          • Aug 2023
          • 6
          I am very interested in clearing the forgotten admin password on my 600 G6 mini tower desktop but I am confused as there appear to be two SPI flash parts on the motherboard. One is a 16pin 256Kbit part and an 8pin 128Kbit part. Would someone inform me which of the two (or both) need to be reprogrammed?
          Also, I already own a programmer which will allow me to read/write the required flash part. I would prefer NOT removing the part from the motherboard. So, I am curious whether there has been success in flashing the part while installed on the motherboard. My programmer has the ability to use a spring clip (similar to a clothespin) which would allow flashing the part without unsoldering the part.
          I would appreciate clarifying how to reflash the part with a clean copy of the bios and clearing the admin password.
          Jim
          • hoaca388
            Badcaps
            • Jan 2022
            • 11224
            • Viet Nam
            Jim
            256Kb or 128Kb is fine.
            • jimflan
              • Aug 2023
              • 6
              Hi hoaca388 -
              Not sure I understand. What do you mean 256Kb or 128Kb is fine? Are you saying that if you reflash either device that will suffice to clear the admin password?
              Also, do you know if it is possible to read and flash the parts while still soldered to the motherboard?
              thanks for the response.
              • hoaca388
                Badcaps
                • Jan 2022
                • 11224
                • Viet Nam
                Hi hoaca388 -
                RED : Just a 256Kb or 128Kb file is enough to remove the password.
                Blue : Yes.
                • jimflan
                  • Aug 2023
                  • 6
                  OK, I understand. Thank you for the explanation.
                  I see earlier in this thread where you supplied the bios dump for a HP ProDesk 600 G6 PCI Microtower PC (9CV80AV). This is my also my model of computer. Will this dump also work for my machine or do I need to supply you with a copy of my locked bios? I thought that maybe each bios dump may have machine serial number information embedded as an additional security measure.
                  I certainly appreciate your help. I will attempt to read my bios flash part today.
                  Take care -
                  Jim
                  • jimflan
                    • Aug 2023
                    • 6
                    Blue : Yes.
                    Just to say thanks again.
                    I ended up reading all the posts I could and finally understood what to do.
                    Initially, I tried reading the 128kb part while soldered to the board but had no luck. I was using the ICSP port on my T48 programmer. Attempted to use the spring clip as well as using 'grabber' clips on each pin. No luck at all.
                    Therefore, I unsoldered the part and modified the dump using RClocker with the chip installed in a zif socket. So, all is good again, the admin password is cleared.
                    Take care -
                    Jim
                    • supertype
                      • May 2013
                      • 14
                      Need help understanding what I'm doing wrong, when I flash the bios dump I get
                      "the bios has recovered its identity data from the embedded controller due to data mismatch"
                      Do I need to flash the 8p chip above it also?
                      Alternatively is the last post saying blank the first 128k/256k on both chips and the PW will be cleared?
                      excuse my ignorance on the subjects.
                      Thankyou.
                      • mactouch
                        • Nov 2018
                        • 81
                        • abudhabi
                        hp prodesk 600 g6 mt . please help me to remove password
                        sn- 4CE203B461
                        • peste
                          • Dec 2016
                          • 12262
                          • ROMANIA
                          sn- 4CE203B461
                          try..
                            HP ProDesk ProDesk 400 G2 Desktop Mini PC (ENERGY STAR) ProDesk 400 i5-6500T Specification for Upgrade or Repair
                            This specification for the HP ProDesk ProDesk 400 G2 Desktop Mini PC (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk ProDesk 400 G2 Desktop Mini PC (ENERGY STAR) boardview and ProDesk ProDesk 400 G2 Desktop Mini PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                            09-12-2024, 03:44 PM
                            HP ProDesk ProDesk 600 G2 Desktop Mini PC ProDesk 600 i7-6700T Specification for Upgrade or Repair
                            This specification for the HP ProDesk ProDesk 600 G2 Desktop Mini PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk ProDesk 600 G2 Desktop Mini PC boardview and ProDesk ProDesk 600 G2 Desktop Mini PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                            09-12-2024, 03:36 PM
                            HP ProDesk ProDesk 600 G2 Desktop Mini PC ProDesk 600 i5-6500T Specification for Upgrade or Repair
