thinkstation p510 bios
  • yukselen
    yukselen
    • Jun 2021
    • 41
    • türkiye
    hello i need thinkstation p510 bios if you can help i would be grateful
    no original bios image
  • hardware1
    • Sep 2021
    • 2948
    • N/A
    Re: Lenovo Thinkstation p510 bıos
    Write your device serial number.
    all donations are welcome,
    • yukselen
      yukselen
      • Jun 2021
      • 41
      • türkiye
      write your device serial number.
      s/n:s4cs5018
      • yukselen
        yukselen
        • Jun 2021
        • 41
        • türkiye
        s/n:s4cs5018
        can you please help
        • hardware1
          • Sep 2021
          • 2948
          • N/A
          Re: thinkstation p510 bios
          Try this one and let me know.
          • yukselen
            yukselen
            • Jun 2021
            • 41
            • türkiye
            try this one and let me know.
            thank you for your interest i returned the device to the owner, it did not work
            • zaheer118
              • Feb 2016
              • 14
              • pakistan
              found 2 file in your link but not working second file machine on off
              1st file monitor light change orange to blue but no display
              can u change me regeon with lenovo site file with my bacup file
              thanks
              when i replace me rgeon seen masage invalid uefi volume
              plaese help
              requast for every one
              thanks
              old file attach
              lenovo thinkstation p510
              s/n pc0qryq7
              mt-m 30b4-sourop
              mother board scorpius rev 1.1
              old file attach​
              • hoaca388
                Badcaps
                • Jan 2022
                • 12325
                thanks
                plaese help
                thanks
                old file attach
                s/n pc0qryq7
                mt-m 30b4-sourop
                old file attach​
                Try it, it's not very satisfactory but hope it helps you
                • zaheer118
                  • Feb 2016
                  • 14
                  • pakistan
                  thank for respond mr hoaca338
                  not working
                  help me if posible
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 12325
                    not working
                    help me if posible
                    Try
                    • Zanzibarbar
                      • Apr 2025
                      • 10
                      Extracted and saved as bin file
                      Machine behaved sluggishly during a change in BIOS parameters I esc from the screen and believe this corrupted the BIOS. After this machine would boot but al drives were not enumerated, and the machine would attempt a boot via NIC.
                      Then it refused to boot. NO beeps Case fans and cpu fan work and red diagnostic triangle is lit but no writing to a correctly formatted USB stick occurs.
                      So I bought a CH341A and after fiddling with the clip connected and read the firmware.
                      Chip is MX25l8006E
                      I recall the installed BIOS was the second to latest version. S00KT72A
                      Motherboard is SCORPIUS REV 1.1 00FC922 (1P) SA70A15451
                      I assume a file compare tool would be helpful, but I do not know how to extract the BIOS from the download package on the Lenovo website.
                      • Zanzibarbar
                        • Apr 2025
                        • 10
                        I erased and wrote the 8.31 mb file attached in the preceding post.
                        diagnostic light is gone no beeps no gpu fans but case and cpu on full
                        is there another file I can try?
                          • 21853
                          Thread merged. Please post the PC serial number
                          • Zanzibarbar
                            • Apr 2025
                            • 10
                            Serial Number
                            MJ060PTL
                            Machine Type Model
                            30B5002EUS​
                            • Zanzibarbar
                              • Apr 2025
                              • 10
                              ok the chip i read and tried to flash is not the BIOS it seems.
                              There is a position on the motherboard with two chip locations. One is empty the other occupied. But I se the chip well enough to identify it.
                              Also the clip does not establish a connection as indicated by illumination of the green light on the programmer.
                              I cannot flash the contents of the MX25l8006E chip as my file is now oversize.
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 12325
                                Look for the chip with the number 128 on its back.
                                • Zanzibarbar
                                  • Apr 2025
                                  • 10
                                  I've never seen such a poorly marked chip chip.
                                  it is a mx25l12873f
                                  but the clip does not connect. Does the board need to be powered on?
                                  ill try to de solder and read from the cradle device on the programmer. Or have a less shaky friend do that.
                                  If unreadable are there sources for a replacement chip?
                                  also how do I reflash the MX25l8006E I attached the read I did before messing about but its now too large to reflash to the chip. By 1 k.
                                  I have no idea if the file I extracted can be repaired in an editor. Much less do I have the skill to do so.
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 12325
                                    it is a mx25l12873f
                                    What did you do with this chip ?
                                    • Zanzibarbar
                                      • Apr 2025
                                      • 10
                                      I misread and thought it was Bios.
                                      read and saved contents attached in previous and tried to force the 16 mb bios onto it.
                                      it erased now.
                                      I tried to flash the file I pulled from it but it errors out as the file is too large.
                                      • hoaca388
                                        Badcaps
                                        • Jan 2022
                                        • 12325
                                        it erased now.
                                        Flash again.
                                          LENOVO ThinkStation P510 ThinkStation P E5-1607V4 Specification for Upgrade or Repair
                                          This specification for the LENOVO ThinkStation P510 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkStation P510 boardview and ThinkStation P510 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-12-2024, 02:15 PM
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • pirati
                                          by pirati
                                          Yesterday, 04:20 PM
                                        • Vesko356
                                          by Vesko356
                                          08-11-2023, 03:27 AM
                                        • AHmad_Salal
                                          Need BIOS Dump/ROM for Lenovo Thinkstation p500
                                          by AHmad_Salal
                                          Hello all,
                                          I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....
                                          11-28-2023, 05:28 AM
