Ga-h67ma-usb3-b3 boardview
  • draak
    • Sep 2022
    • 11
    • south africa
    looking for this GA-H67MA-USB3-B3 boardview
  • Aleksej N.
    • May 2024
    • 5
    • Lithuania
    Same, serching for this as well
    • xinom
      • Sep 2017
      • 3
      • Russia
      Welcome
      • SHA_S
        • Aug 2023
        • 3
        • Russiya
        Thanks a bunch, xinom!​
        • Aliencomputres
          • Aug 2019
          • 210
          • România
          Originally posted by xinom
          Welcome
          Thanks!
          • Maciej Skoczylas
            GV-N3060GAMING OC-12GD - boardview for specific revision
            by Maciej Skoczylas
            I have problem with my graphic card GV-N3060GAMING OC-12GD.
            2 smd elements are missing.
            I've already bought a boardview but it's not complete - that specific area is not attached. I tried with different similar models but without success.
            This is my PCB
            And this is screen of boardview
            As you see those missing capacitors or resistors are not on boardview.
            Also i compared every single transistor from boardview to real card and everything is related.
            It seems that this one is like extra.
            Could anyone...
            08-09-2025, 10:26 AM
          • CG_Dionysos
            MacBook Pro 15-Inch | Mid 2017 | A1707 | 820-00928-A | 3,1 GHz i7, Radeon Pro 560, 16GB, 1TB | Boardview and Schematics
            by CG_Dionysos
            I am looking for the boardview file and the matching schematics (PDF) for the following MacBook Pro:
            • Model: A1707
            • 15-inch, Mid 2017
            • 3.1 GHz Core i7
            • 16 GB RAM
            • Radeon Pro 560
            • 1 TB SSD
            • Board number: 820-00928-A
            I already searched the forum, but so far I haven’t found a matching boardview for this board. In several posts I came across, it was also mentioned that the uploaded files were often incorrect.
            Thanks in advance!
            Greetings from Germany...
            09-16-2025, 06:43 AM
          • Ash_sus10
            Request for BoardView for ASUS TUF Gaming A15 (DA0NJM8C0 Rev C)
            by Ash_sus10
            I'm looking for the BoardView file for an ASUS TUF Gaming A15 motherboard, specifically DA0NJM8C0 Rev C (Quanta NJI). My repair technician has identified a power regulation issue, and we need the BoardView to trace the power lines accurately....
            07-17-2025, 03:59 AM
          • Jag013
            HP OMEN 15-ax204ns Boardview and schematics
            by Jag013
            Hi, I need the boardview and schematicsfor an HP OMEN 15-ax204ns laptop, purchased in 2018, with the following specifications:
            • Processor: Intel(R) Core(TM) i7-7700HQ CPU @ 2.80GHz
            • RAM: 4.00 + 4.00 GB
            • Hard Drive: 1TB
            • Product ID: 00325-96088-89605-AAOEM
            • N/S: 5CD70805T8
            I’m trying to repair a short circuit in the battery charging section.
            If you can help me locate the boardview and schematics or a boardview file, I would really appreciate it.
            Thank you for your help!...
            07-02-2025, 02:15 AM
          • rmfr1225
            Surface PRO 7 Plus 1960 Boardview needed
            by rmfr1225
            Hello everybody,
            I have the schematics already of this device but no boardview and it is being very difficult to locate the fault.
            I have +3P3VAS but then nothing else, I suspect something related with 1V8 regulators, but without boardview it is very difficult to locate those components and or pads to test.
            Does somebody has the boardview of this model? Or can point out where to test?
            Thanks!
            05-12-2025, 03:29 AM
