Request A2115 820-01779 boardview
  • jackycan
    • May 2019
    • singapore
    can share A2115 820-01779 boardview?
  • mon2
    • 14355
    Re: Request A2115 820-01779 boardview
    Here you go, not easy to find...recently purchased to repair the same. We were 99.99% done without the aid of the schematics - had a shorted tantalum that we found through sub-dividing the logic board regions. Found the shorted tantalum, removed it but board would not power up. Embarrassed to say that the dual mosfet we removed for the 5v rail was not soldered onto the board properly - it just took much more heat and flux to place it back. While we were checking against these schematics, the meter probe shifted the improperly soldered mosfet. So, in a way, the schematics helped
    The board worked perfectly after this reflowing of the dual mosfet.
    https://www.badcaps.net/forum/showthread.php?t=107156
    • rattale
      • Nov 2015
      • 28
      • morocco
      thank you
      • rohitdadu
        • Aug 2017
        • india
        thanks
        • Rickkap
          • Aug 2015
          • 134
          Thank you for sharing
          • saturn21
            • Oct 2017
            • Moldova
            thanks
            • Royco
              • Jul 2024
              • Indonesia
                • 21196
                Look up, post 2
                • Chozo69
                  • Oct 2019
                  • united kingdom
                  thank you for board view file
                  but
                  I have issue with 2019 iMac. all works fine except for speakers crackle during the chime when turning on.. unsure what the issue is, but have diagnosed with known working speakers, cpu swaps, re-casing board and even replacing with known working firmware chip but still have not found out the cause, hoping these schematics will help. if you have any other idea please feel free to say
                  • joutrade
                    • May 2015
                    • 24
                    • united kingdom
                    but
                    hello, i would check all the capacitors a resisters around the sound socket under the on the right hand side. sometimes if you remove the socket #with tool you maybe damaged an capacitor
                    • macbang
                      • Jun 2024
                      • FRANCE
                      Thanks a lot for the share, 1st led is off for me. Looking for this schematic to find out what's wrong
                      • firulilla
                        • Jun 2014
                        • 64
                        • spain
                        thanks for sharing
                        regards
                        • anquach10
                          • Nov 2018
                          • usa
                          THANK CYOU SO MUCH MON2 FOR SHARING
