lenovo AIO M90z 30min auto shutdown
  • musanide
    JQUB
    • May 2020
    • 86
    • zambia
    Good day all
    i have a lenovo m90z that shutsdown every 30min, i have tried flashing a clean bios but , there is no change ,Please any advice will be appreciated
    • 20807
    Re: lenovo AIO M90z 30min auto shutdown
    Originally posted by musanide
    Good day all
    Its probably an management engine firmware issue,the firmware needs cleaning https://www.badcaps.net/forum/showpo...41&postcount=3
    • musanide
      JQUB
      • May 2020
      • 86
      • zambia
      i tried cleaning today, it stopped shutting down after 30min, but the fan is still running at fullspeed, and if i shut the machine for 30mins, then it wont post, unless i reprogram the bios chip.....Thanks for your time
      • teknikbursa
        • Sep 2014
        • 64
        • turkey
        pls send your original bios.
        • musanide
          JQUB
          • May 2020
          • 86
          • zambia
          thanks, i started having this problem since 2019, and i ended up loosing my original bin file.... but i downloaded the bin that i have uploaded,..... its the one that has fixed the 30min shutting down, but the fan is running at fool speed, and if i switch off the machine for some time then it wont boot on the screen........
          • musanide
            JQUB
            • May 2020
            • 86
            • zambia
            and the orignal serial number is S4YPF04, the one inn the bin belongs to the machine the bin was extracted from
              • 20807
              Try this one.The ME FW is cleaned,plus your serial number added using a hex editor.
              You can also edit the serial and other info using wflash2.exe with command line options. To get wflash2.exe download the bios update and extract the exe using winrar or 7-zip ,and read the readme.txt file
              9BKT42A https://download.lenovo.com/ibmdl/pu.../9bjy42usa.exe
              Code:
              *             3. Flash Program Options             *
              *   The default operation of the flash update program is to use the    *
              *   graphical user interface provided by the AFUWINGUI program. You can  *
              *   also run the program from a DOS command box (with Administrator    *
              *   privilege) by running "flash.cmd". Before running the "flash.cmd",  *
              *   please change the command line to the options you need. The command  *
              *   is:                                  *
              *   wflash2.exe [option1] [option2] ... [optionX]             *
              *   [OPTIONS]                               *
              *   /h        Show help messages.                 *
              *   /bb       Program boot block.                 *
              *   /ncb       Program all non-critical blocks           *
              *   /rsmb      Preserve all SMBIOS structures.           *
              *   /clr       Clear BIOS settings.                 *
              *   /ign       Ingore BIOS version check.              *
              *   /sn:nnnnnnn   Update system serial number (up to 20 characters).  *
              *   /csn:nnnnnnn   Update chassis serial number (up to 20 characters). *
              *   /mtm:nnnnnnn   Update machine type and model number (up to 20    *
              *           characters).                     *
              *   /tag:nnnnnnn   Update system asset tag (up to 25 characters).    *
              *   /uuid      The flash utility will generate an Universally    *
              *           Unique Identifier (UUID), replacing the one that   *
              *           is currently in the system.             *
              *   /logo:<filename> Change logo. The max supported size of logo file   *
              *           is displayed on the screen during the compressing.  *
              *   /cpu       Update CPU microcode.                *
              *   /reboot     Automatic reboot after all requests done.      *
              *   /pass:nnnnnnn  Input current system password.            *
              *   The following example shows how to update system asset tag number   *
              *   to "1234567" use command line:                    *
              *    wflash2.exe /tag:1234567                      *
              *   The following example shows how to update bios and update system   *
              *   asset tag number by one command:                   *
              *    wflash2.exe bios.rom /tag:1234567                  *
              *   The following example shows how to change the power-on logo.     *
              *    wflash2.exe /logo:myfav.bmp                     *
              *   Note: A flash update image using these program options should be   *
              *      tested carefully before widespread usage.            *
              • classicandy
                Lenovo G50-80 Auto Power On when AC is detected
                by classicandy
                Hi Everyone,
                I have a Lenovo G50-80 that auto powers On when AC (Charger) is connected. I have checked the BIOS settings and there is no option to turn On or Off that feature as it is in some HP EliteBooks. I did update the BIOS and still same.
                I then flashed the BIOS with a different bin file I downloaded here, It worked (didn't auto power on) for some time (after testing up to 5 times) but has now started again to auto power on when AC is connected.
                The CMOS battery voltage is 3v. I have also tested with two main batteries as well. I would be glad if anyone...
                03-21-2024, 05:48 AM
              • bigbily09
                lenovo g460 auto shutdown
                by bigbily09
                i have here a lenovo g460 la-5751p motherboard the problem is it shutoff when booting to windows logo, i tried replace cpu and re-thermal paste and pad,increase fan speed, ram, harddrive, reflash bios ic, charger replace but still the problem exist what should be the problem, please help last time it boots to windows but it shutsdownrandomly but now it doesnt enter to desktop windows now on logo it shutoff already
                02-10-2022, 10:53 PM
              • kalilinux25
                LENOVO B480 auto power on and no display
                by kalilinux25
                Device : Laptop
                Brand : Lenovo
                model: LENOVO B480
                board: LA48 MB 11264-1M.48.4TD01.01M
                Issue: auto power on , No display tried flashed bios same issue
                S0_PWR_GOOD - 3.2v
                PM_DRAM_PWRGD - 3.3v
                VCC_GFXCORE - 0v
                VCC_CORE -0.8
                IMVP_PWRGD -3.3v
                SYS_PWROK -0v
                DDR3_DRAMRST# -1.5v
                PCI_PLTRST# -3.3v
                12-04-2023, 01:09 AM
                Lenovo 3000 Series Schematic
                Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
                3000 C100 laptop with Braille keyboard
                Lenovo 3000 C
                C100, C200 - 15-inch XGA screen
                Lenovo 3000 N
                N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
                N500 - 15.4 inch screen.
                Lenovo 3000 V
                V100, V200 - 12.1-inch WXGA models
                Lenovo 3000 G
                G400, G410, G430, G450, G455, G510, G530, G550, and G560...
                10-04-2024, 06:05 AM
                Lenovo IdeaPad 120S Notebook 100 Specification for Upgrade or Repair
                This specification for the Lenovo IdeaPad 120S Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 120S boardview and 120S schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 120S...
                09-06-2024, 06:40 AM
