GA-AX370-Gaming 5 BIOS chip MX25U12873F doesn't erase properly
  • Haganai.NMWP
    • May 2022
    • 5
    • Poland
    Hello
    I can't properly erase BIOS chip MX25U12873F.
    I can read it and write it, but before correct write, it have to been erased, but when I click erase program shows success, but when I try do blank verification I have message "chip disconnected".
    I use CH341A programmer with 1.8V adapter and clips.
    When I try read or write it takes 3~5 minutes and "run" LED on programmer is blinking. When I try erase, it takes up to 15 seconds, but "run" LED isn't blinking and after that, chip isn't erased correctly.
    I also tried to unprotect that chip but software show's it's already unprotected. I tried solutions from that website https://khandishnetwork.com/2021/01/...rror-solution/
    My motherboard is GA-AX370-Gaming 5. That motherboard have dual BIOS, but both are corrupted.
  • Vesko356
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    Re: BIOS chip MX25U12873F doesn't erase properly
    https://www.badcaps.net/forum/showpo...9&postcount=10
    https://www.badcaps.net/forum/showpo...3&postcount=21
    Become a Badcaps supporter
    Thanks to all supporters.​
    • Haganai.NMWP
      • May 2022
      • 5
      • Poland
      Re: GA-AX370-Gaming 5 BIOS chip MX25U12873F doesn't erase properly
      I checked with multimeter the connection before I posted here and all pins have connection.
      I also tried a lot of version of NeoProgrammer and AsProgrammer including these in the second link.
      I will check Colibri and tell if it works.
      • Haganai.NMWP
        • May 2022
        • 5
        • Poland
        Nope, Colibri doesn't help.
        I will try to desolder the chip, because I noticed something, every time when I read data from chip I had different checksum.
        It may took some time, because delivery of something i need to desolder the chip, may took up to two months.
          • 21968
          If you have a powered USB hub try that .
          • Haganai.NMWP
            • May 2022
            • 5
            • Poland
            I desoldered chip and use socket SOP8 200~209 mil.
            Now I can properly erase and write that chip.
            Topic solved.
            • acedogblast
              by acedogblast
              11-02-2024, 05:13 PM
            • DynaxSC
              ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
              by DynaxSC
              Hi
              I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
              08-04-2025, 12:20 PM
            • testaccgta
              Unable to verify IC or write/erase/flash BIOS file to XMC QH128AHIG SPI chip using NeoProgrammer/AsProgrammer
              by testaccgta
              Hi, everyone!
              I've recently acquired two brand new SPI chips to replace the one currently in my Acer A514-54G laptop MB (FH5AT LA-K092P). The reason why I'm replacing the current SPI chip is because I had some difficulties with a third-party IT assistant who pretty much lacked the soldering skills and ended up destroying the current SPI chip soldered to my MB from factory.
              I've decided to do this on my own because I spent the past month or so learning some soldering skills and BIOS modding through Badcaps and WinRaid forums, hence the attempt. I've also chosen to buy...
              09-01-2024, 08:24 PM
            • neuralnet
              RT809F faulty?
              by neuralnet
              I have recently purchased the RT809F and am doing some test dumps/erase/reads of bios chips before I attempt anything in anger. While my unit is capable of identifying the correct chip types, it keeps telling me there is no chip attached.
              I've tried both the clip and the spring loaded holder that came with the unit, both are giving me the same result. I've cleaned the legs of my test chips with alcohol, lightly sanded them and cleaned them up with an eraser! Here's an example;
              001: Serial number:20210324115525-026373, Programmer firmware version:...
              04-29-2021, 02:08 PM
            • BMCappelletti
              Asus Chromebox CN62 - wrong chip put on BIOS reader
              by BMCappelletti
              Long story short:
              - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
              - gave the computer to his son a couple years later
              - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
              - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
              (seems like the story was not that short)
              He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
              01-08-2025, 07:27 PM
