Bios dump request hp proliant ml30 server
  • terrarob
    • May 2019
    • 9
    • mexico
    HI!!!, does anyone have a bios dump from a hp proliant ml30 (A14SGT1 MB 14033-1 822185-001$A1 BOARD) thanks in advance,
  • peste
    • 13370
    • ROMANIA
    Re: Bios dump request hp proliant ml30 server
    post the original bios
    • terrarob
      • May 2019
      • 9
      • mexico
      thank you sir, here you go
      • Habble7
        by Habble7
        Suspected Cause:
        Troubleshooting Attempts:
        05-22-2025, 07:28 AM
      • haitham sharabati
        by haitham sharabati
        Hello engineers šŸ˜€,
        I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.šŸ˜
        šŸ”§ Device Info:
        - Model: HP 15-da2007ne
        - Product Number: 8XF55EA#ABV
        - Serial Number: CND0338P0D
        - CPU: Intel Celeron N4000
        šŸ’€ Problem:šŸ˜…
        - Device shows ā€œAdministrator Passwordā€...
        08-07-2025, 04:54 AM
      • Citymin
        by Citymin
        S/N : 5RNK9FFT70...
        08-05-2025, 05:12 AM
      • DynaxSC
        by DynaxSC
        11-17-2023, 10:56 AM
      • greelidd
        K6604J Vivobook RTX 4070 BIOS Dump Request
        by greelidd
        Hi all! Tldr: need a bios dump (.bin format) for K6604J (rtx 4070 and i9-13980hx)
        Longer story: my vivobook stopped booting after i switched out the thermal paste. I think the BIOS got corrupted. Everything i tried didn’t work until finally i decided to buy a CH341A BIOS programmer and just send over the BIOS directly from another PC onto the BIOS chip. I connected fine and backed up the existing BIOS, but i can’t find a clean BIOS that’s a .bin format. And I tried using UEFI software to extract all the files from the ASUS BIOS .exe file and get to the .bin but it was a .302...
        09-01-2025, 06:14 PM
