Please help! SAPPHIRE PULSE Radeon RX 580 8G G5
  • timekn
    • Feb 2022
    • 11
    • slovenian
    I need help if any of you have a SAPPHIRE PULSE Radeon RX 580 8G G5 boardview or shematics
    problems missing components
    next to the driver chip
    thanks for the help
  • samsam411
    • Feb 2014
    Re: Please help! SAPPHIRE PULSE Radeon RX 580 8G G5
    I have the same card, I could measure some parts for you. Could you post a photo?
      AMD Radeon R9 290 / R9 380 / R9 390 Schematic & Board View
      The Radeon R9 290 was a high-end graphics card by AMD, launched on November 5th, 2013. Built on the 28 nm process, and based on the Hawaii graphics processor, in its Hawaii PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon R9 290. The Hawaii graphics processor is a large chip with a die area of 438 mm² and 6,200 million transistors. Unlike the fully unlocked Radeon R9 290X, which uses the same GPU but has all 2816 shaders enabled, AMD has disabled some shading units on the Radeon R9 290 to reach the...
      10-01-2024, 12:46 PM
      Thermal pad thickness for various laptop GPU / Graphics Cards
      ASUS Dual RTX 2070 OC 8GB
      ASUS ROG STRIX RTX 3080 OC
      ASUS ROG STRIX RTX 3090
      ASUS TUF Gaming RTX 3080 OC Edition
      ASUS TUF GTX 1660 S-O6G GAMING
      EVGA RTX 3060 Ti XC GAMING 8GB
      EVGA RTX 3060 XC GAMING 12GB GDDR6
      EVGA RTX 3080 FTW3 ULTRA GAMING
      EVGA RTX 3080 TI FTW3 ULTRA GAMING
      EVGA RTX 3090 XC3 ULTRA GAMING 24GB
      Gainward RTX 2080 Phoenix GS Specs
      Gainward RTX 3070 Phoenix 8GB
      Gainward RTX 3080 Ti Phoenix
      GIGABYTE AORUS RTX 3080 MASTER 10G
      02-09-2024, 08:08 AM
    • MonkeydBrian
      SAPPHIRE PULSE Radeon RX 570 8GB 3.3 short to ground
      by MonkeydBrian
      Hi i have a SAPPHIRE PULSE Radeon RX 570 gpu that when power on it doesn't get get detected by bios and fans spin at max rpm.. when i checked the bottom pci e section of the card the 4th pin from the right is short. i can find where it leads to to find solution
      06-23-2023, 12:40 PM
      AMD Radeon RX Vega 56 / RX Vega 64 Schematic & Board View
      The Radeon RX Vega 56 is a high-end graphics card by AMD, launched on August 14th, 2017. Built on the 14 nm process, and based on the Vega 10 graphics processor, in its Vega 10 XL variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX Vega 56. The Vega 10 graphics processor is a large chip with a die area of 495 mm² and 12,500 million transistors. Unlike the fully unlocked Radeon RX Vega 64, which uses the same GPU but has all 4096 shaders enabled, AMD has disabled some shading...
      10-01-2024, 01:07 PM
      AMD Radeon RX 470 / RX 580 Schematic & Board View
      The Radeon RX 470 is a mid-range graphics card by AMD, launched on August 4th, 2016. Built on the 14 nm process, and based on the Ellesmere graphics processor, in its Polaris 10 PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX 470. The Ellesmere graphics processor is an average sized chip with a die area of 232 mm² and 5,700 million transistors. Unlike the fully unlocked Radeon RX 480, which uses the same GPU but has all 2304 shaders enabled, AMD has disabled some shading units...
      10-01-2024, 12:52 PM
