Hello all, i have go throught the internet and looking for biostar GF8100 M2+ TE schematic or boardview but i couldnt get anything. so in here, i wanna ask if someone have that motherboard schematic or boardview. thanks
by selectivetaoHello fellows,
I am putting a feeler out for a schematic (or ideally boardview) for the Biostar B660-T Silver motherboard.
I had let my guard down and decided to trust the Biostar supplied Windows based BIOS flash tool, only to find that the system would not POST upon restart.
no problem I thought - I would just flash using my trusty CH341 and be on my merry way.
Upon inspecting the board and locating its Winbond NOR, I found it in a rather precarious spot nestled between the RAM slots and PCIe slot and right next to a rather meltable-looking...-
12-13-2024, 09:37 PM -
Good day members, hope everyone is doing well.
I am looking for a schematic and/or boardview for the Biostar motherboard model "A10N-9630E". I have this board that fails to boot.
The power supply is fine - All voltages pass with multimeter.
3.3V is present at the Power ON pins of the board
I think both the North and South Bridge are integrated in the Processor.
I will get another memory stick and see if the board boots.
I have disconnected all drives and peripherals while conducting these tests.
Any suggestions are welcomed.... -
by newtestHello, I want to learn about the main biostar H110MG Pro D4 - IH11M-MHS for long-term use, so I need its schematic and boardview, thank you for your time.
* Translated by google so if my words are dry or misleading, please forgive me.-
by BleedCapI'm in need of schematic or boardview for this motherboard please.
I don't have access to other sites that have the schematic.
In case anyone here got it and willing to share.
Thank you.
by PacoGThello firends
i search the schematic or boardview
I have this motherboard, but I can't find the schematic or the boardview.
The problem is that on the chip marked where 3V should be, there are 5 volts, which indicates that the two are connected.
So the computer doesn't turn on, and the 3V disappears after a few seconds.
The original problem was that when I turned off the computer, the fan stayed on and saw that it was bad since it was directly in the 5V area.
The new problem arose after removing the bad chip.
3V and 5V remained together,...-
Channel: Schematic Requests ONLY!
08-19-2025, 08:25 PM -
- Loading...
