I need ASRock A320M-DGS bios bin file
  • keygen
    • Apr 2014
    • 11
    • turkiye
    Dear members.
    I need bios bin file for ASRock A320M-DGS rev 1.04
    Black screen after updating the bios
    Thank you in advanced
  • lotas
    • Jan 2016
    • 4787
    • Russia
    Re: I need ASRock A320M-DGS bios bin file
    And what does not suit you bios from the official site. Rename it to bin.
    https://www.asrock.com/mb/AMD/A320M-...ex.ru.asp#BIOS
    See spi flash maybe at 1.8v
    • keygen
      • Apr 2014
      • 11
      • turkiye
      i flashed with 1.8v but same.black screen.on offical site ROM file doesn't work.help pls
      • keygen
        • Apr 2014
        • 11
        • turkiye
        i have backup bios but wrong. can it be fixed
        **************************wHk2YdYL_roseEggpi6Y8
          • 21889
          https://mega.nz/file/ENoGmIgR#uaI6HB...L_roseEggpi6Y8
          If the offical site ROM doesn`t work then your problem is somewhere else.
          • keygen
            • Apr 2014
            • 11
            • turkiye
            I found the backup bios file and succeed.
            Last edited by SMDFlea; 10-17-2022, 04:35 AM. Reason: added bios from external link
            • selekop
              • Aug 2017
              • 21
              • türkiye
              https://mega.nz/file/pNxGgYbQ#uaI6HB...L_roseEggpi6Y8
              thanks brooo
              • to5it0
                Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                by to5it0
                Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                I have opened the laptop and identified the main BIOS chip...
                10-24-2025, 01:35 AM
              • nolaryie
                BIOS .bin file for ASRock B450M Steel Legend
                by nolaryie
                Hi, I’m looking for a clean, working BIOS .bin dump (16MB) for the ASRock B450M Steel Legend motherboard.
                I’ve already tried flashing the official ASRock ROM file via CH341A, but it won’t post — I believe the capsule format is incompatible.
                Any BIOS version that supports Ryzen 5 2600 is fine (e.g., P2.30–P3.60).
                If anyone has a working board and can dump the BIOS using CH341A or flashrom, I would really appreciate your help.
                Thank you!
                08-06-2025, 12:01 PM
              • paulwal
                Updating a BIOS on ASROCK
                by paulwal
                Hi. I am not too up on installing BIOS so am looking for a little direction installing a BIOS update.
                https://www.asrock.com/MB/AMD/AB350%...index.asp#BIOS
                I have an ASROCK AB350 Pro4 that is running a P3.00 BIOS.
                CPU is AMD Ryzen5 1500X which I believe is a "Summit Ridge."
                Before I go ahead and update it to the latest version, I thought I would ask whether my plan is right to try and be sure I don't make a mess of things.
                It appears that the latest BIOS for this chip is the 5.80; therefore I need to install (one at a time)…
                10-02-2023, 04:13 PM
              • Citymin
                by Citymin
                S/N : 5RNK9FFT70...
                08-05-2025, 05:12 AM
              • iZakre
                HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
                by iZakre
                Hello everybody!
                To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
                The thing is that I had installed TeamViewer and could log into the computer...
                02-19-2023, 02:27 PM
