Bios for Asrock h110m-HDV r1.02
  • DECoZ97
    • Jun 2021
    • 7
    • Cuba
    i need a dumped bios to repair this board
  • bassbabu368
    Banned
    • Oct 2018
    • 49
    • india
    Re: Bios for Asrock h110m-HDV r1.02
    Asrock h110m-HDV BIOS clean bios and try me
    • DECoZ97
      • Jun 2021
      • 7
      • Cuba
      thanks you
      • DynaxSC
        by DynaxSC
        11-17-2023, 10:56 AM
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • edward card
        BIOS Request: MSI Raider GE68 HX 14VGG-287US (Board: MS-15M2) - No POST
        by edward card
        I'm requesting a working BIOS dump for my MSI laptop, which I plan to provide to a repair technician.
        Make/Model: MSI Raider GE68 HX 14VGG-287US Board Model: MS-15M2 (Note: I have the serial number ready to be provided to the technician for DMI transfer)
        Problem Description: The laptop fails to POST. The only sign of life is the GPU fan spinning up after a couple of minutes. The screen remains black.
        Background / Fault Event: The system was working perfectly. The issue occurred immediately after entering the BIOS advanced menu and exiting with "Discard...
        10-06-2025, 05:41 AM
      • Kentsfield
        Lenovo Thinkcentre M75n DMI Data extraction from dumped BIOS
        by Kentsfield
        I got a Lenovo Thinkcentre M75n (MT-M 11G5 PF3XG5V3) with a semi-bricked bios.
        Short recap: I want to add an external GPU via the M.2 slot (Oculink). It does work but has some problems with the onboard GPU of the Ryzen 3 3300U. So I used Smokeless_UMAF to disable it. Since then I don't get any video via the external GPU nor the iGPU and Can't access the BIOS, but the PC does boot to the OS.
        I desoldered the flash IC MX25U12872F and dumped the flash.
        I also downloaded the newest BIOS and have it as a .bin file (I loosely compared the contents...
        08-04-2025, 07:46 AM
      • Exim
        ASRock N100M, no picture no boot, but semi-alive
        by Exim
        Hi guys,
        I managed to semi-kill an ASRock N100M board after updating Bios from 1.10 to 2.01. It's a zombie now, dead, but not dead.
        ASRock N100M special features:
        - CPU soldered to board, small Intel 12th gen
        - iGPU
        - four POST LEDs
        Problem after updating Bios to 2.01 using the in-Bios update tool: no picture, no boot.
        I am not sure anymore if it booted at least once successfully after updating the bios to 2.01, maybe not, I can't remember. I think it did not.
        Symptoms:
        - no picture/signal on any of the display connectors,...
        04-01-2025, 02:36 PM
