NEED HP 290 G1 Microtower BIOS FX-ISL-4
  • okbalord
    • Jun 2017
    • 204
    • Algeria
    HELLO I NEED BIOS DUMP FOR HP 290 G1 Microtower BIOS FX-ISL-4 REV A
    ty
    OKBALORD
    • 21533
    Re: NEED HP 290 G1 Microtower BIOS FX-ISL-4
    ty
    Post your backup .
    • okbalord
      • Jun 2017
      • 204
      • Algeria
      ok bro ---
      OKBALORD
        • 21533
        ty
        Try this one,if theres any problems with it download the bios from the support page,run the exe and select copy to save a 16MB virgin bios.
        https://support.hp.com/gb-en/drivers...53?sku=1QN00EA
        • okbalord
          • Jun 2017
          • 204
          • Algeria
          ty bro but dont work
          and no heat on cpu
          OKBALORD
          • Goverdown
            • Dec 2021
            • 5
            • Côte d'Ivoire
            Hello dear friends of the community,
            I have here the Bios you need,
            I tested it and it works well
            Smile at Grace, Well-being is in sharing By Giving something else to You
            • pierrelourens
              • Jan 2022
              • South Africa
              ho to install the bois update for hp 290 g1 ?
              • danao
                • Nov 2017
                • 4
                • Pol
                Hello.
                Do You can some one repair for HP 290 G1 SFF Biusness PC bios file?
                From Menlo MB Rev: A17519-1?
                Please ME remove too.
                • Goverdown
                  • Dec 2021
                  • 5
                  • Côte d'Ivoire
                  Hello friend ,
                  you can try the BIOS that I posted, most often it works on another motherboard revision, but first I advise you to make a backup of the original BIOS.
                  you have nothing to lose (apart from a bit of time), it's better than not trying
                    • 21533
                    Originally posted by danao
                    Hello.
                    You should read the PM i sent you ,i moved your original post to a new thread. Your bios is different (BID0843F) https://www.badcaps.net/forum/showthread.php?t=103941
                    • Habble7
                      by Habble7
                      Suspected Cause:
                      Troubleshooting Attempts:
                      05-22-2025, 07:28 AM
                    • haitham sharabati
                      [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                      by haitham sharabati
                      Hello engineers 😀,
                      I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                      🔧 Device Info:
                      - Model: HP 15-da2007ne
                      - Product Number: 8XF55EA#ABV
                      - Serial Number: CND0338P0D
                      - CPU: Intel Celeron N4000
                      - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                      💀 Problem:😅
                      - Device shows “Administrator Password”...
                      08-07-2025, 04:54 AM
                    • Citymin
                      by Citymin
                      S/N : 5RNK9FFT70...
                      08-05-2025, 05:12 AM
                    • DynaxSC
                      by DynaxSC
                      11-17-2023, 10:56 AM
                    • greelidd
                      K6604J Vivobook RTX 4070 BIOS Dump Request
                      by greelidd
                      Hi all! Tldr: need a bios dump (.bin format) for K6604J (rtx 4070 and i9-13980hx)
                      Longer story: my vivobook stopped booting after i switched out the thermal paste. I think the BIOS got corrupted. Everything i tried didn’t work until finally i decided to buy a CH341A BIOS programmer and just send over the BIOS directly from another PC onto the BIOS chip. I connected fine and backed up the existing BIOS, but i can’t find a clean BIOS that’s a .bin format. And I tried using UEFI software to extract all the files from the ASUS BIOS .exe file and get to the .bin but it was a .302...
                      09-01-2025, 06:14 PM
