Clean me plz
ASROCK h55M-LE Clean me plz
Re: Clean me plz
You can get the full bios from the support site. And please include the model number in your thread title in future .
https://www.asrock.com/mb/Intel/H55M-LE/index.asp#BIOSComment
Re: Clean me plz
i need bin OR ROM fileyou can get the full bios from the support site. And please include the model number in your thread title in future .
https://www.asrock.com/mb/intel/h55m-le/index.asp#bios
this files is exeLast edited by pooya_pm; 04-06-2021, 09:30 AM.Comment
Re: ASROCK h55M-LE Clean me plz
Download and extract the 1.80 "Instant flash" zip file and extract it , rename H55MLE_1.80 to anything you like,with a *.rom or *.bin extension ,for example H55MLE_1.80.BIN .Most programmers will load the file as-is
.Last edited by SMDFlea; 04-06-2021, 09:39 AM.Comment
by gabrieljma1Hello everyone,
I’m looking for a full raw 16 MB BIOS dump for an ASRock Z790-CX (DDR5) motherboard.
The board powers on (fans spin, RGB lights on, RAM LEDs active), but there is no display output and the VGA and BOOT LEDs stay lit.
I’m using an Intel i9-14900KF CPU (14th gen), and it seems the BIOS version on my board doesn’t support it yet. I tried to flash the official ASRock BIOS file (renamed .ROM → .BIN) directly using my RT809H programmer, but it didn’t work — monitor stays on but with black screen, so I believe the ASRock update file is not a complete...-
by EximHi guys,
I managed to semi-kill an ASRock N100M board after updating Bios from 1.10 to 2.01. It's a zombie now, dead, but not dead.
ASRock N100M special features:
- CPU soldered to board, small Intel 12th gen
- iGPU
- four POST LEDs
Problem after updating Bios to 2.01 using the in-Bios update tool: no picture, no boot.
I am not sure anymore if it booted at least once successfully after updating the bios to 2.01, maybe not, I can't remember. I think it did not.
Symptoms:
- no picture/signal on any of the display connectors,...2 Photos -
by MasterCapI have an AsRock Taichi 7900xtx, and the minimum fan speed is way too high at 1000rpm, and thats with it's Quiet BIOS switch on, and me setting the fan profile as low as it goes, while on.
Now 1 thing I could do is just make some circuit to put in between the fan the the GPU, and leave the fan on all the time, but anytime the GPU is sending the PWM for min speed, I'll just send something lower and quieter.
But does anyone know what how AsRock usually sends the PWM to the fans on GPUs and mobo's? Is it from the MCU that's often near the 12V inputs and fan jack ? Or is... -
by nolaryieHi, I’m looking for a clean, working BIOS .bin dump (16MB) for the ASRock B450M Steel Legend motherboard.
I’ve already tried flashing the official ASRock ROM file via CH341A, but it won’t post — I believe the capsule format is incompatible.
Any BIOS version that supports Ryzen 5 2600 is fine (e.g., P2.30–P3.60).
If anyone has a working board and can dump the BIOS using CH341A or flashrom, I would really appreciate your help.
Thank you!-
by zklgfsHi,
I have an AsRock B560 Pro4 (boardview: https://www.badcaps.net/forum/troubl...pro4-schematic) that's completely dead (it doesn't even turn on the power supply when the power button is pressed or the power button pins are shorted). I do get about 3.4V on the power button pin, but 1.8VSB isn't there. The resistance to ground on the inductor PL53 is only about 0.1-0.4 Ohms. Am I correct in assuming that there must be a short... - Loading...
