fujitsu esprimo q920 bios dump
  • digitalpc
    • Jun 2016
    • 305
    • .DLL
    hi can anyone repair this bios dump for
    problem is no video
  • peste
    • 15538
    • ROMANIA
    Re: fujitsu esprimo q920 bios dump
    problem is no video
    try..
    If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our boardview / schematic archive.
    It only takes 1 minute:
    https://www.badcaps.net/settings/subscriptions
    • dannu
      • Hungary
      thanx bro
      • korhylol
        • Feb 2022
        • Russia
        hi, i have got fujitsu esprimo q920 that beeps(3 short-pause and repeat). Most manuals says that somethnig wrong with RAM, but i replaced it with 100% worked one, and nothing changed. Could it be the BIOS image problem?
        • Stanley(Stan-Lee)
          • Jul 2022
          • Slovakia
          How did you flash bios chip? My Q920 beeps 3 times with good ram.
          • usercs
            • Nov 2019
            • 5
            • Kocsorhegy
            Hi! I have a Q920/MRP , with bricked bios, after smd cap burn, (changed the cap to good)
            I flashed it with the Q920 image, it works fine but there is no fan control.Fan not working. (With the bricked bios the fan starts in two speed, so the fan/ control is ok i think )
            The board is slightly different from the Q920
            Can somebody send me the MRP image?
            Thank you very much.
            So its Q920/MRP
            Uefitool finds this error in the original image:
            parseVolume: file with duplicate GUID 06DC8ECB-97D5-4EDF-85F3-C9B410977F53 //2 times, if it matters
            • usercs
              • Nov 2019
              • 5
              • Kocsorhegy
              //// update , problem sloved. So i got constant beep with the original bios. ( it maybe not bricked? ) It was constant beeping, with bios reset, etc. The Q920 ( not MRP) bios worked fine.
              Tried to flash the latest, i got constant beep too.
              So i read out that the original bios is 1.43 ( there is no such MRP bios on the website, ) * it was constant beeping with the latest MRP bios too.
              So i flashed the 1.42 , --- nothing changed just constant beeping....
              So i picked out the cpu, and turned on the pc. It turned on! No . Just jokeing. But after reseated the cpu, and i turned it on, and works fine.
              So i had to switch on the pc with the cpu is out.
              It happened the same with Fuji E920 pc too . ( cpu was 1840 just for testing.)
              Fan is now working.
              If you download the original bios from the fuji webpage, in the dos folder there is a UPD file 17.25Mb . You can grab it to the UEFITOOL 0.28
              Then extract it, and you got a 16,3mb file.
              After i put that in the original size of the MX25L6473E SOP8 with the XGPro software ( tl 866 v3)- so it cuts at 8MB.
              And it works. It has the same ending if you see with the hex editor, as the original bios file.
              • Loki_Fido
                BIOS for Fujitsu Esprimo FH-X/E2 FMVFXE2B
                by Loki_Fido
                Hi ya folks,
                I have a Fujitsu Esprimo All-In-One with a BIOS issue.
                Model FMVFXE2B
                SN BZ1Y02417
                MB makring SPARKLE MB UHD 18408-1M
                I donwloaded the BIOS from Fujitsu site, but the latest version 1.11's BIOS body size is bigger than the my older version 1.04.
                Therefore i am unsure how to merge the BIOS withouit increading the overall size of the file.
                BIOS download site for this model from Fujitsu
                https://azby.fmworld.net/app/custome...ame=FMVFXE2B&k...
                06-21-2026, 08:41 PM
              • TacticalFahrrad
                [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                by TacticalFahrrad
                I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                06-30-2025, 04:09 AM
              • EGUG
                Bios Dump for Fujitsu Esprimo D7010n with Mainboard D3823-A2 required
                by EGUG
                I have a Fujitsu PC with defective bios after bios update from Windows. Therfore I need a bios dump to fix it.
                Serial number EICK023345
                Mainboard D3823-A2
                Hope somebody can help me.
                04-10-2025, 02:05 AM
              • salim harb
                Fujitsu Esprimo E500 E85+ (D2991-A13 GS3) BIOS dump
                by salim harb
                I need a clean BIOS dump for Fujitsu Esprimo E500 E85+ desktop,
                motherboard model: D2991-A13 GS3.
                The machine is not booting, so I need the full BIN file for programming
                with an external SPI programmer (CH341A).
                If anyone has a working dump (4MB / 8MB depending on chip),
                please share it.
                Thanks in advance!
                08-16-2025, 12:47 PM
              • MohammedBathabet
                Request BIOS dump for Fujitsu LIFEBOOK AH47/J (DAFH6BMB6A0)
                by MohammedBathabet
                I need a BIOS dump file for my Fujitsu LIFEBOOK AH47/J laptop.
                Motherboard model: DAFH6BMB6A0
                The system BIOS got corrupted and now the laptop powers on but does not boot.
                I already tried the official Fujitsu support site, but the downloadable BIOS is only in .exe format and does not contain the raw .bin file needed for programming the BIOS chip directly with a programmer (CH341A).
                If anyone has a working BIOS dump (.bin) for this model, please share it.
                Thanks in advance!...
                09-24-2025, 05:59 AM
