M710q Please my bios clean me
  • hoaca388
    Badcaps
    • Jan 2022
    • 11700
    #41
    Originally posted by kafkaf
    Hello, I cannot access the bios settings of Lenovo Thinkcentre M710q. I tried the shared files, but I could not get an image. I am sharing my original file and product information. I would be glad if you could help, thank you.
    machine type : 10yc
    model number : s00p2m
    SN : PC1H6TVD
    Product : 10ycs00p2m
    Are you using Chrome OS ?
    • Bios Cracker
      • Oct 2024
      • 315
      • India
      #42
      Lenovo m710q
      Type 10YC
      S/N PC0Y8EAY
      Problem - Attached in Pic. Not booting further, need to change to windows
      Any Help.
      • Bios Cracker
        • Oct 2024
        • 315
        • India
        #43
        Originally posted by Bios Cracker
        Lenovo m710q
        Type 10YC
        S/N PC0Y8EAY
        Any Help.​
        hoaca388 SMDFlea
        • fromthebrink
          • Mar 2025
          I found a Lenovo ThinkCentre 710q (7th gen i3, 8gb ddr4, 256 gb) and monitor ( TIO24 gen 3) at a thrift store for $15 dollars.
          A friend needed a gaming setup with a newer CPU (he has a gen 4 i5-4460). Games like DayZ and CS2 crashed often. His rig had bad airflow since it was near the floor and full of dust. I wanted to fix both issues: give him better performance in a small system that could sit off the floor.
          My plan was to upgrade the guts, attach it to the monitor, and save space. But it didn't go that smoothly.
          When I powered it on, it was running Chrome OS—Amazon's locked-down version. This made it useless outside of Amazon's work environment.
          Worse, the BIOS had no UEFI options to boot from another drive!
          That kicked off a long process. I learned a lot and noted every step, including links. I had to dig through tons of incomplete resources, ( Credit to assquitoe https://www.badcaps.net/forum/troubl...me?view=thread at bad caps for the most comprehensive post I could find on this project to date)
          1. Flashing the BIOS: Installing and running Flashrom to remove ChromeOS bios
          Steam deck nuance with removing read/write
          passwd deck
          sudo steamos-readonly disable \\protection before and after installation
          \\ We will do this again at the end to leave it how we found it
          Downloading Flashrom from Arch repository on Linux with Steam OS. https://www.reddit.com/r/SteamDeck/c...ur_steam_deck/
          sudo pacman-key --init
          sudo pacman -Syy
          sudo pacman -Syu
          sudo pacman-key --populate holo
          sudo pacman-key --populate archlinux
          sudo pacman -S vi \\Installing a package to test out repository set up
          sudo pacman -S flashrom
          Prepare the CH341A Chip programmer
          Unplug the PC and remove the CMOS battery before any changes.
          BIOS chip is under the SSD; it says "Winbond" and starts with "25" or "24".
          Pin 1 is near the circle on the chip. Match red wire of the SOIC clip to pin 1.
          25 series = left side of programmer; 24 series = right side.
          USB-C male to USB-A female adapter-https://www.amazon.com/dp/B0C4KWHRT5?ref=ppx_yo2ov_dt_b_fed_asin_title
          Using the above adapter, plug CH341A into available usb slot. This is where the adapter from USB A to C comes into play, steam deck limited to one USB-C port...
          Red light means that we are getting power.
          green light on opposing side of USB interface means we are actively running.
          Time to test and use the set up!
          sudo flashrom --programmer ch341a_spi -r new1.bin (see video above for command source)
          sudo flashrom --programmer ch341a_spi -r new2.bin
          sudo flashrom --programmer ch341a_spi -r new3.bin
          new#.bin are new files that we create when reading the old/already present bios Son the chip.
          to ensure their validity we can compare hashes between each read of the present bios file
          sha512sum new1.bin \\( see video above)
          sha512sum new2.bin
          sha512sum new3.bin
          Results of above entries should yield the exact same strings of numbers and characters as each new#.bin is a copy of the same bios
          As this is a sanity/safety check, I have NO idea what I would of done if the values were different. If they had been dissimilar I probably would have re-seat the SOIC8 clip and tried again
          Once we verify all hashes are the same, we can identify the default directory of the new#.bin files. This way we can upload the stock Lenovo bios for the 710q without needing to specify a directory location in the final write command (bios link & video link)
          On the steam deck the default directory was he "Home" screen of the SteamOS flavor of Linux. (/home/deck)
          After unzipping the bios .rar file, I placed the stock bios in same location as .bin files (again, /home/deck)
          sudo flashrom --programmer ch341a_spi -w 11.6.10.3197+outimage.bin ("1.6.10.3197+outimage.bin" was default name of bios from badcaps forum link)
          wait 15-30 min.
          final result (see video) should verify write and say "VERIFIED"
          at this point we need to see if it worked. unplug programmer.
          Plug display cable, power, and keyboard to boot into bios (f1 spam)
          If you see the Lenovo splash screen, it worked. BIOS date in BIOS menu should be dated to ~ 2017
          Now update the BIOS to the newest version.
          sudo steamos-readonly enable
          sudo passwd -d deck
          2. Updating BIOS 2 electric boogaloo flash installation media
          - use this guide step by step to create the media for up to date bios Specifically want: BIOS Update (USB Drive Package) m1ajt5ausa.zip
          In BIOS:
          Disable PXE Boot (Devices -> PXE Option ROM -> Disable)
          Set boot to USB HDD
          PC was defaulting to boot from a network connection regardless of any changes to boot order.
          set to load from USB hdd after PXE boot disabled
          next time you boot you should see on screen instructions as the PC recognizes BIOS update media on flash drive
          I left my serial number and other meta data the same. I didn't want to find out if changing any of that would alter the boot (although I don't think it would)
          It will restart several times, then take you back to Lenovo splash screen
          press f1 to get back to bios, you should see updated BIOS version from 03/2025. Success!
          That is it if you just came here for flashing the BIOS. The rest will be about installing Windows from USB ( in my case, the same USB, just formatted again) and discussion about using the set up for light to intermediate gaming with an externally mounted GPU.
          3. Installing Windows from flash installation media
          Had issues with either USB port or bad Win 10 installation media. This created a boot loop.
          Fix:
          • - Use another port, I did both at the same time, unsure which one fixed it
          In BIOS: set CSM to "enabled", boot mode to "auto", and boot priority to "legacy first"
          ** goes without saying, but after Win 10 set up, f1 back into BIOS set up and change boot order to primary drive that you just installed Windows on or you will boot loop!
          • THXFX
            • Mar 2023
            • 5
            • Costa Rica
            #45
            Originally posted by peste
            Re: Please my bios clean me
            try..
            can someone upload peste bios file again? the link provided by peste don't work, when open the link it give this error: Invalid File Specified
            • menshawy
              • Aug 2013
              • 400
              • egypt
              #46
              where is DMI PLEASE
              • hotcrossedbuns999
                M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                by hotcrossedbuns999
                My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                3. I could only locate two chips that look like bios chips. Could someone verify this
                01-03-2025, 12:32 PM
                LENOVO ThinkCentre M710q ThinkCentre M i5-6500T Specification for Upgrade or Repair
                This specification for the LENOVO ThinkCentre M710q can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkCentre M710q boardview and ThinkCentre M710q schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                09-12-2024, 01:58 PM
                LENOVO ThinkCentre M710q ThinkCentre M i5-7500T Specification for Upgrade or Repair
                LENOVO ThinkCentre M710q ThinkCentre M i7-7700T Specification for Upgrade or Repair
