Lenovo Thinkcentre M93P bios
    Re: Lenovo Thinkcentre M93P bios
    thanks working great
      Hey guys I'm working on a M93p and have got issues writing to these two chips N25Q032A,N25Q064A
      My CH341 can read these chips fine but when i try to erase and program it gets stuck it does nothing
      <<N25Q064A [3.3V]>>
      <<N25Q064A [1.8V]>>
      Current programmer: CH341a
      13:00:49
      Erasing memory...
      anyone else have this or a similar issue?
      Solved: i put a jumper on the 5v-3.3v pins converting my 3.3v mod back and it worked, also bios fixed my dead M93P many thanks everyone!
        I need ME Clean
        Thanks for hellp
          Hello, I need help, please, I have a Lenovo ThinkCentre M93P 10AAS3B200, it turns on but does not give video, can someone share the bios of 4 and 8 mb?
            post here both bios (4MB and 8MB)...
              Re: Lenovo Thinkcentre M93P i5 4590t 2GHz
              Originally posted by kmmng View Post
              I also had the problem with wrong flashing wrong EC firmware and seems your EC dump has actually helped me bring the computer back to life.
              Thank you so much! I flashed a newer EC by mistake, which turned my computer into a brick. Those steps and the dump made by sniffchic saved my hardware.
              In my case EC version in BIOS is still wrong, but computer seems work without any problems.
              Albo I had multiple attempts to make the pin 1&2 trick work.
              Thanks again.
                Lenovo ThinkCentre M93p Type 10A8
                hi everyone i hope someone could give me a working bios or clean/repair my bios. pc turn on but no display. i already tried replacing the cpu and ram but still no display. i also try to flash bios i downloaded from other thread but still doesn't work.
                  Re: Lenovo ThinkCentre M93p Type 10A8
                  Post the serial number.
                  https://www.badcaps.net/forum/showthread.php?t=103569
                    s/n: PC0BRFL8
                      s/n: PC0BRFL8
                      M93p Desktop (ThinkCentre) - Type 10A8
                      Become a Badcaps supporter
                      Thanks to all supporters.
                        Thank you unfortunately problem is still the same.
                          Check hardware issues
                            i just realised that you give me the wrong ec file because the ec i uploaded is 1mb in size but your is just 128kb.
                              Make no mistake, EC is extracted from the .exe file.
                                that's weird. my ec chip is winbond 25q80dvsig.
                                  Here
                                    Hello all,
                                    i got a m93 tiny with motherboard is8xt ver 1.1
                                    it appears to be kinda bricked. So as soon as dc cable is plugged in i get a green led , fan spinning, cpu getting warm . It dosent matter is the ram sticks are in or not. Also i dont get any beeping. What is the solution for this? Can i blindily re load the bios from a usb?
                                      Hello All,
                                      Have M93m TypeAB no screen, fan spins. Tried clear cmos. Suspecting BIOS corrupted. Can't find anywhere clean bins. Attaching my bins, read with CH341A, chip MXIC 25L3273E & 25L6473E. Maybe someone could help me with those. S/N PC05GLF4
