dell optiplex 7060 bios bin need bios
  • Spori
    • Mar 2023
    • 6
    • Hrvatska
    Re: dell optiplex 7060 bios bin need bios
    I don´t know how to read it.
    I try but nothing happens.
    It have 16 pins and CH341a have 8 pins.
    Service tag is 9XL63Y2
    I tried other Chip with 8 pins on graphic card and it works with it.
    • hardware1
      • Sep 2021
      • 2948
      • N/A
      You should have an adapter converting from 16Pins to 8Pins, 16 to 8 Clip or a small PCB with 16Pin Footprint for your IC Package.
      all donations are welcome,
      • Spori
        • Mar 2023
        • 6
        • Hrvatska
        I was searching and i dont have it.
        Will this work?
        I have to order it..
        In program for programmer (ch341a),there is no support for that chip
        • hardware1
          • Sep 2021
          • 2948
          • N/A
          Will this work?
          I can't see if the Clip have 16 Pins or not. Anyway, I don't prefer to use a Clip, you could face some problems with it.
          I will attach Images for the Adapter I meant.
          • Drugzy
            • Apr 2023
            • 13
            • AUS
            Just wondering if anyone could help me recover this BIOS?
            Dell 7060 SFF.
            Have two that are dodgy, this one is either Service Tag 13KYVV2 or JBWDMP2 (Unsure which one)
            One I received which would not boot and the other power went out during a BIOS update.
            Any help would be appreciated
            Cheers
            Mike
            • Drugzy
              • Apr 2023
              • 13
              • AUS
              #26
              Hi Guys,
              As post above
              Here is the second corrupt BIOS - Dell 7060 SFF
              Cheers!
              Mike
              • hardware1
                • Sep 2021
                • 2948
                • N/A
                #27
                Dell 7060 SFF.
                Cheers
                Mike
                Here's your New BIOS file, try it and let me know.
                Service Tag: 13KYVV2.
                • Drugzy
                  • Apr 2023
                  • 13
                  • AUS
                  #28
                  Thanks, this is working! However there is an administrative password set - what is it, or can it be removed?
                  Thanks again, any chance of a working one also for Service Tag JBWDMP2?
                  Cheers!
                  • Drugzy
                    • Apr 2023
                    • 13
                    • AUS
                    #29
                    Cheers!
                    Answered my own question, there is a jumper on the PCB which clears the password, PC fixed!!! Thanks heaps @hardware1, could you supply one for Service Tag JBWDMP2 also?
                    Much appreciated
                    • hardware1
                      • Sep 2021
                      • 2948
                      • N/A
                      #30
                      Hi Guys,
                      As post above
                      Cheers!
                      Mike
                      Here's the other BIOS, try it.
                      Service Tag: JBWDMP2.
                      • Drugzy
                        • Apr 2023
                        • 13
                        • AUS
                        #31
                        Thanks so much
                        • hardware1
                          • Sep 2021
                          • 2948
                          • N/A
                          #32
                          Thanks so much
                          You're welcome.
                          • Drugzy
                            • Apr 2023
                            • 13
                            • AUS
                            #33
                            You're welcome.
                            Just letting you know both worked flawlessly, my first time dumping a BIOS chip, all with a $10 CH431A programmer.
                            Awesome site with all the information!
                            • DUGi
                              • Jun 2023
                              • 4
                              • Slovakia
                              #34
                              Hello, I need to recover bios on my Dell Optiplex 7060 SFF after unsuccessfull bios upgrade caused by power outage. Can you advice me what I will need to flash it ? As I understand I will need IC SOP16 cable and CH341A USB programmer. Are they all the same or do I have to buy specific one ? I found EEPROM programmer with USB MX25L6405 version 2 from local reseller. Can I use bios from this thread ( Dell OptiPlex 7060 (V_1.24.0).rar) or do I need Service TAG specific BIOS ? What Software will I need ?
                              • DUGi
                                • Jun 2023
                                • 4
                                • Slovakia
                                #35
                                Update: Chip is Winbond 25Q256JVFQ 1905 16 pin, Machine Service TAG H4Q1GV2
                                • DUGi
                                  • Jun 2023
                                  • 4
                                  • Slovakia
                                  #36
                                  Hello, Actually chip on faulty motherboard is MX25L25673GMI-08G
                                  I finally put everything together, CH341A programmer, SOP16 clip which I rewired to 8pin using diagram on the picture.
                                  I disconnected everything from motherboard except CPU, connected clip to the chip.
                                  Installed drivers and run NeoProgrammer 2.2.0.3.
                                  But software is unable to detect chip.
                                  What I'm doing wrong ?
                                  Do I have to remove CPU as well ?
                                  Do I have to power up PSU ?
                                  If clip is disconnected from Motherboard when I plug the power cord, PC is staring up beeping.
                                  When Clip is connected it not starting after plugging the power cord.
                                  If I have to power up PSU is it just short green and black wire from it ?
                                  • DUGi
                                    • Jun 2023
                                    • 4
                                    • Slovakia
                                    #37
                                    I did a progress by modifying programmer to 3.3V by lifting pin28, soldered a wire between the power pin 28 and the output of the 3.3 V regulator as well as pin 9 of the CH341. I noticed more variations of that "conversion". which one is correct ?
                                    I'm able now identify the chip and read the data from it. BUT when I write to the chip verification is failing and data are not written correctly.
                                    I tried to use different USB 3 ports, powered USB3 hub etc. Without luck.
                                    Any ideas ?
                                    • Drugzy
                                      • Apr 2023
                                      • 13
                                      • AUS
                                      #38
                                      Any ideas ?
                                      When I was doing this for the first time I also had issues - I removed the 3.3v mod from the programmer and all my reading/writing issues disappeared - It was on this particular chip too so without the mod it won't do any damage.
                                      Also the chip clips can be unreliable, de-soldering is more reliable if you are handy with an iron.
                                      • bembeno
                                        • Feb 2016
                                        • 313
                                        • egypt
                                        #39
                                        need help with repairing bios dell optiplex 7060 tower
                                          • 21874
                                          Re: need help with repairing bios dell optiplex 7060 tower
                                          https://www.badcaps.net/forum/showthread.php?t=103569
                                          You MUST:
                                          • Post under a related thread if it exists
                                          • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 )
                                          • Post what the problem is,be specific - Black screen,no boot,running slow,password.
                                            Do NOT post "clean me","clear bios","clean bios","bios need" or other such terms
                                            DELL OptiPlex 7060 OptiPlex 7000 i5-8500T Specification for Upgrade or Repair
                                            This specification for the DELL OptiPlex 7060 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OptiPlex 7060 boardview and OptiPlex 7060 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                            09-12-2024, 03:44 PM
                                            DELL OptiPlex 7060 OptiPlex 7000 i5-8500 Specification for Upgrade or Repair
                                            DELL OptiPlex 7060 OptiPlex 7000 i7-8700T Specification for Upgrade or Repair
                                            09-12-2024, 03:36 PM
