I need ASRock A320M-HDV bios bin file
  • nissimezra
    • 177
    Dear members.
    I need bios bin file for ASRock A320M-HDV rev 1.09.
    Black screen after updating the bios
    Thank you in advanced
  • Claudiomfa
    • Nov 2015
    • 455
    • Portugal
    Re: I need ASRock A320M-HDV bios bin file
    Post your bios backup
    • nissimezra
      • 177
      Thank you sir.
      After finish the update it show me update success
      https://mega.nz/#!kA9ABArL!bL5Di7mDq...3-4pOjaBlaLURQ
      • Claudiomfa
        • Nov 2015
        • 455
        • Portugal
        try and report
        • nissimezra
          • 177
          try and report
          OMG, this worked man thank you very much, god bless you
          • masonmala
            • Oct 2021
            • India
            • masonmala
              • Oct 2021
              • India
              try and report
              download this file. but cant extract it file format damage shows it. help
              • lotas
                • Jan 2016
                • 4618
                • Russia
                The archive is in order, update your WinRar.
                • RIZAL22552255
                  • Jul 2022
                  • 4
                  • indonesia
                  try and report
                  thank u
                  • repaircentree
                    • Nov 2022
                    • 11
                    hi i need bios dump which is version 7.30 or later to support ryzen 5 5600g. attached is my old bios which has no display. A320M-HDV
                      • 20999
                      https://www.asrock.com/mb/AMD/A320M-HDV/index.asp#BIOS
                      • repaircentree
                        • Nov 2022
                        • 11
                        thanks for the reply, i see the bios file type ends in .30, do i simply rename it to .bin and flash with ch341a?
                          • 20999
                          Yes, rename it to .bin or .rom
                          • aaahaaa
                            • Apr 2025
                            i got a kllisre a320m-amd, has a windbond w25q128jwsq and has corrupted bios i need a bin file that would work for this please... would an asrock bin work or a msi? if any please provide
                              • 20999
                              No it won`t work, start your own thread please.
                              • nolaryie
                                BIOS .bin file for ASRock B450M Steel Legend
                                by nolaryie
                                Hi, I’m looking for a clean, working BIOS .bin dump (16MB) for the ASRock B450M Steel Legend motherboard.
                                I’ve already tried flashing the official ASRock ROM file via CH341A, but it won’t post — I believe the capsule format is incompatible.
                                Any BIOS version that supports Ryzen 5 2600 is fine (e.g., P2.30–P3.60).
                                If anyone has a working board and can dump the BIOS using CH341A or flashrom, I would really appreciate your help.
                                Thank you!
                                08-06-2025, 12:01 PM
                              • paulwal
                                Updating a BIOS on ASROCK
                                by paulwal
                                Hi. I am not too up on installing BIOS so am looking for a little direction installing a BIOS update.
                                https://www.asrock.com/MB/AMD/AB350%...index.asp#BIOS
                                I have an ASROCK AB350 Pro4 that is running a P3.00 BIOS.
                                CPU is AMD Ryzen5 1500X which I believe is a "Summit Ridge."
                                Before I go ahead and update it to the latest version, I thought I would ask whether my plan is right to try and be sure I don't make a mess of things.
                                It appears that the latest BIOS for this chip is the 5.80; therefore I need to install (one at a time)…
                                10-02-2023, 04:13 PM
                              • Citymin
                                by Citymin
                                S/N : 5RNK9FFT70...
                                08-05-2025, 05:12 AM
                              • iZakre
                                HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
                                by iZakre
                                Hello everybody!
                                To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
                                The thing is that I had installed TeamViewer and could log into the computer...
                                02-19-2023, 02:27 PM
                              • Forest79
                                by Forest79
                                However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                                07-23-2023, 07:39 AM
