fujitsu D2942-B12 GS1
  • hazim
    • Mar 2016
    • 62
    • egypt
    Pls i need bios for mb fujitsu d2942- b12-gs1 core i5
  • ddhlawi
    • Feb 2017
    • 165
    • algerian
    Re: fujitsu D2942-B12 GS1
    post her eold bios
    • rabsonnjala
      mujahid
      • Apr 2021
      • 19
      • malawi
      i also have the same motherboard, its bios has a password find the attached dump
      • Sha321
        • May 2021
        • 9
        • India
        Hi sir
        I NEED BIOS d2942-b12 gs 1
        Demb
        Bro check this file and confom
        • rabsonnjala
          mujahid
          • Apr 2021
          • 19
          • malawi
          Originally posted by Sha321
          Hi sir
          Demb
          your bios is 100% good.
          • TacticalFahrrad
            [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
            by TacticalFahrrad
            I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
            06-30-2025, 04:09 AM
          • Habble7
            by Habble7
            Suspected Cause:
            Troubleshooting Attempts:
            05-22-2025, 07:28 AM
          • EGUG
            Bios Dump for Fujitsu Esprimo D7010n with Mainboard D3823-A2 required
            by EGUG
            I have a Fujitsu PC with defective bios after bios update from Windows. Therfore I need a bios dump to fix it.
            Serial number EICK023345
            Mainboard D3823-A2
            Hope somebody can help me.
            04-10-2025, 02:05 AM
          • DynaxSC
            by DynaxSC
            11-17-2023, 10:56 AM
          • DynaxSC
            Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
            by DynaxSC
            I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
            It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
            I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
            11-06-2022, 05:22 PM
