Buenas noches, un favor alguien que pueda ayudarme con este problema esta placa me la regalaron por que tenia el problema que la prendes pasan dos o tres segundos y se apaga pasan tres segundo y se vuelve a prender sola y así sigue hasta que la desconectas. Ya le cambie fuente de poder, procesador, memoria RAM, pila, lo que no probé es medir voltajes si me pudieran indicar que voltajes buscar y donde, aparte estuve buscando información en internet y en algunos vídeos indicaban que el problema se debe a falla de la BIOS, tengo el programador y el programa pero me falta en archivo .BIN si alguien pudiera ayudarme por favor desde ya muchísimas gracias de corazon.
Gigabyte h61m-ds2 rev 1.2 bios
Re: Gigabyte h61m-ds2 rev 3.0 bios bin file
Use english -
Re: Archivo bin de Gigabyte h61m-ds2 rev 1.2 bios
As far as I can understand (even though I haven't learnt a lot of Spanish) is he has a GB H61M-DS2 board that powers up for 3 seconds and then shuts down, and that he said the problem is the BIOS went bad. He asks for a BIN file with the BIOS.Main rig:
Gigabyte B75M-D3H
Core i5-3470 3.60GHz
16GB DDR3-1600
Samsung SH-224AB DVD-RW
Delux MG760 case
Good evening, if Dan81 is correct, my problem is in the BIOS programming and I can not get the .bin file, try to program the BIOS with another .BIN file from another GIGABYTE board but it did not work, please, if you could help me I will really appreciate Dan81Comment
Try this bios .Attached Filesif you find these attachements useful please consider making a small donation to the site
by macabookHello everyone,
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by cr4zychrissHello everyone,
I have successfully used a CH341A programmer and can read/write/verify both flash chips, but using my backups/extractions has failed to restore power. The root cause is likely a corrupted Intel Management Engine (ME) region or an incompatible EC/BIOS pairing. System & Hardware Details- Barebone / Chassis: TongFang GK7MRFR
- MB: MB: GK5MP5X V1.0 Prod :GK5MRFV10T04201310281
- Rebrand: PC Specialist
by piratiHello everyone,
Hi Everyone,I need help with this strange Gigabyte laptop,it turns on with black screen and after 30sec fans on the Max for few seconds and it shuts down,I think the bios is bricked,They say it is Clevo under the hood,there is nowhere on motherboard what is the model which is strange,i will write S/N and P/N from the motherboard,thats only what is writen there and upload old bios,if anyone can help,Thanks!
Gigabyte A5 X1
From motherboard:
S/N: 1TNH55ER1350895
P/N: 6-77-NH55ERQY-D02-2CGB
On sticker from the back of the laptop:
S/N: SN21351J000657...-
- Loading...
