Nvidia Tesla P40 schematic/boardview
  • ocx_juergen
    • Jul 2021
    • Carinthia
    Hello together,
    i am struggeling with a Tesla P40 - i measured a short in the near of the ncp 81274 but there was no short -by mistake i desoldered 2 caps and a resistor and lost them in the 6th dimension.
    Does anyone have a schematic/boardview for the P40 or show me maybe the values of the caps / resistor ncp81274 for pin 29 and 30 (FB and comp) or can i use the default Value from the NCP datasheet?
    regards Juergen
  • piernov
    NVidia bumpgate
    by piernov
    Just archiving everything related to bumpgate since most stuff has disappeared from Google. Maybe people will finally take the time to read some of it and stop shouting "reflow gpu" at every occasion but rather try to understand what the real issue is…
    Interesting parts about the failure analysis are "Why Nvidia's chips are defective" and "Why Nvidia's duff chips are due to shoddy engineering"
    May complete this post at a later date with more details.
    Basically issue is a combination of thermal dissipation of the chip with hotspot,...
    03-27-2021, 10:34 AM
  • mbassi
    Nvidia Quadro P2200 schematic or boardview
    by mbassi
    I’m troubleshooting an NVIDIA Quadro P2200 graphics card that isn’t recognized by Windows. I’ve discovered a missing SMD probably 180 Ω 0402 resistor on the opposite side of the PCB from the GDDR5 memory chip labeled M1.
    To proceed with the repair, I’m looking for a schematic or boardview file for this card — or any other confirmation regarding proper spare parts needed.
    If anyone has access to service documentation, layouts, or high-res boardview screenshots, I'd be grateful for any shared resources....
    07-19-2025, 05:00 PM
  • olliec420
    Nvidia Tesla P40 (Q0V80A) Enterprise GPU, I put the power cable on backwards.
    by olliec420
    Ok I screwed up big time and hoping I can fix. I will break down what happened and the images.
    • Have Dell PowerEdge R730
    • Bought Tesla P40
    • Researched power cables and order correct one, pic had two black connectors in photos
    • Power cable arrived, same connectors (EPS-12v) on both ends
      Both sides are the same plug but different colors. The listing stated that colors would be random. OK I plug it in, red side to riser board, black side to GPU.
    • Power on.
    • System immediately turns off.
    • I only had 1 PSU plugged in and it was blinking orange, I thought I drew too much so I plugged in
    02-11-2025, 07:29 PM
    NVIDIA GeForce RTX 3080 / RTX 3090 Schematic & Board View
    The GeForce RTX 3080 is an enthusiast-class graphics card by NVIDIA, launched on September 1st, 2020. Built on the 8 nm process, and based on the GA102 graphics processor, in its GA102-200-KD-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 3080. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The GA102 graphics processor is a large chip with a die area of 628...
    10-02-2024, 08:52 AM
    GIGABYTE GV-N4090GAMING NVIDIA GeForce RTX 4090 Gaming OC Boardview
    RTX4090...
    10-28-2024, 01:40 PM
