looking for a working bios file motherboard code is ms-16gd1 ver:1.1
Msi ms-16gd
Re: Msi ms-16gd
The full bios is available at MSI support, download the correct bios for your model,extract the zip file. https://www.msi.com/Laptop/support/cx61#down-biosComment
Re: Msi ms-16gd
thanks everybody for responce............finally i done it here the fileComment
Re: Msi ms-16gd
Great. Always check on MSI ,the full bios is usually there if you check with the full laptop model number.Comment
this is GOOD dump for MSI CX61-2PC--MS16GD tested
Attached FilesComment
Hello, I have an MSI device and I can't remove the BIOS password. I'm sharing the original BIOS and its information with you. Can you remove the BIOS password? 😊
Model: MSI MS-16GD
MB INFO
E89382 MV-4
94V-0
MS-16GD1 VER: 1.1Attached FilesComment
Type the laptop serial number, full name and model, motherboard model, etc.
read the forum rules..https://www.badcaps.net/forum/troubl...before-postingComment
by CityminHi all,
S/N : 5RNK9FFT70...-
Channel: BIOS Requests ONLY!
by Forest79Hello,
However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...-
by maanee11Hello Everyone,
I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...-
Hello to all of you! I need help with a BIOS file.
The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.-
by Fr33manHello everyone,
I soft BRICKED my Lenovo IdeaPad laptop (black screen with led lights on, responsive keyboard backlight, fans spinning) after messing about with a Github tool called Smokeless. I am now attempting to reflash the bios through USB, but I am not sure if I extracted the correct BIOS ROM file to flash, and I also could not find the correct file name to rename it to (GLCrisis.bin, GLCN.bin, Currom.bin??). In addition to attempting to reflash the Bios with a USB, I have also performed the following activities:
*Novo button power on
*Disconnected internal battery...-
- Loading...
