ASRock B450 Pro4 bios
  • Pawelen
    • Jul 2025
    • Poland
    Does someone have this motherboard bios that is ready to write on the IC?
  • Grucha98
    Asrock Fatal1ty B450 Gaming-ITX/ac wont boot, cpu phases turn off after a few seconds. Bios?
    by Grucha98
    Hi I'm working on that asrock motherboard. It had shoted mosfet on cpu phase(changed) and 1 cap on bottom side(changed). Led driver is probably shotted too because voltage on one leg of this chip is 0.5v to 5v (its in loop rising and falling) its's RT7905 and i cant find datasheet :/ But its only led driver so mb should work without it. When i desolder it on the same leg is 5v all the time.
    If i start mb on all cpu phases is 1v1 for a few seconds only. Other voltage are present. So i tried to flash bios with the newest on official site and it doesnt help. Its not normal extension...
    01-19-2025, 03:40 PM
  • macabook
    by macabook
    🧩 Initial Issue
    07-24-2025, 02:17 PM
  • gabrieljma1
    Request: Full BIOS dump for ASRock Z790-CX (DDR5)
    by gabrieljma1
    I’m looking for a full raw 16 MB BIOS dump for an ASRock Z790-CX (DDR5) motherboard.
    The board powers on (fans spin, RGB lights on, RAM LEDs active), but there is no display output and the VGA and BOOT LEDs stay lit.
    I’m using an Intel i9-14900KF CPU (14th gen), and it seems the BIOS version on my board doesn’t support it yet. I tried to flash the official ASRock BIOS file (renamed .ROM → .BIN) directly using my RT809H programmer, but it didn’t work — monitor stays on but with black screen, so I believe the ASRock update file is not a complete...
    10-08-2025, 03:32 PM
  • spintop
    Asrock B365 Pro4 Bios needed - No Display
    by spintop
    Hi, need help here.
    Asrock B365 Pro4 motherboard can turn on, cpu fan spinning, graphics card fan spinning, but no display, black screen.
    No shorted mosfet found and no visible faulty capacitor, board looks ok. Bios chip is desoldered, read using CH341.
    Asrock B365 Pro Rev 1.01 motherboard
    Bios P4.00​...
    02-08-2024, 09:34 AM
  • DynaxSC
    ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
    by DynaxSC
    Hi
    I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
    08-04-2025, 12:20 PM
