Asus B450M TUF Gaming PRO II - from modified .bin back to .cap
  • xZeroCool
    • 13
    • Philippines
    Is there anyway I can make my bios file back to .cap file? I have already tried putting back the first 2kb of the file but when I use the EZ Flash it doesn't recognize the BIOS File.
    When I use the bios flashback (already did the bios renamer) the bios light just keeps staying green, seems like it cannot the read the file.
    I haven't removed the BIOS from the motherboard, the pin is different from other motherboard or try doing the TPM header bios flash trick, I don't have the tools to do it.
    I have attached my modified .bin file to be converted to .cap file
  • to5it0
    by to5it0
    10-24-2025, 01:35 AM
  • nolaryie
    BIOS .bin file for ASRock B450M Steel Legend
    by nolaryie
    Hi, I’m looking for a clean, working BIOS .bin dump (16MB) for the ASRock B450M Steel Legend motherboard.
    I’ve already tried flashing the official ASRock ROM file via CH341A, but it won’t post — I believe the capsule format is incompatible.
    Any BIOS version that supports Ryzen 5 2600 is fine (e.g., P2.30–P3.60).
    If anyone has a working board and can dump the BIOS using CH341A or flashrom, I would really appreciate your help.
    Thank you!
    08-06-2025, 12:01 PM
  • Citymin
    by Citymin
    S/N : 5RNK9FFT70...
    08-05-2025, 05:12 AM
  • maanee11
    Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
    by maanee11
    Hello Everyone,
    I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
    It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
    In the website, you can only see specs etc.
    I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
    11-08-2025, 04:08 AM
  • m1ch43lzm
    by m1ch43lzm
    Hi everyone
    09-06-2025, 05:47 PM
