I need help with mini pc Beelink u55 bios
  • Milovanovic1992
    • Aug 2024
    • 31
    • Serbia
    Hi. I got an Beelink u55, which won't boot. Just white and blue light for 5 seconds, and then it shuts down. I noticed that something drains Bios battery. I have put new one, but after short time voltage drops from 3+ to 2volts. I didn't find any obvious short on board. Not ssd and ram issue. Does somebody have bios dump for this model? I would try that solution too. Serial number is 5005U1EF10180.
  • Milovanovic1992
    • Aug 2024
    • 31
    • Serbia
    Here is original BIOS dump. It is GigaDevice 24q64CWIG. I can't even find exe bios update online. I desoldered bios chip, and after that bios battery is not drain anymore. So i suppose it's firmware problem, or the bios chip itself.
    • meisi
      • Mar 2025
      • Italy
      I have the same problem but my lack of experience can't tell which one is the bios chip between the two, what about the little sop8 chip next to it (gd25d10ctigr 1mbit SPI flash)? Can you provide a dump of that one?
      • meisi
        • Mar 2025
        • Italy
        I'm sorry i'm going to explain myself.
        I have a Beelink U55 that is now bricked after a bios update (which someone else did).
        Reading a little bit more i discovered that this update was for the EC (that is the 1mbit chip i was referring to) and i managed to find the correct EC .bin on the beelink website and flash it. (It would still be useful to compare the two if you can get a dump of yours, i managed to do it without dissoldering it and connecting with the SOP8 claws). I will PM you with the link.
        My minipc is still bricked tho, i will look into the Q64CWIG (big chip) in the following days and provide my dump if it can be useful.
        • Milovanovic1992
          • Aug 2024
          • 31
          • Serbia
          I will read that chip too, and i will post here soon as i get.
            • 21844
            Beelink U55 bios updates https://dr.bee-link.cn/?dir=uploads%2FEQ%2FU55%2FBIOS
            • Milovanovic1992
              • Aug 2024
              • 31
              • Serbia
              Here is mine second chip.
              • Milovanovic1992
                • Aug 2024
                • 31
                • Serbia
                Originally posted by SMDFlea
                Thanks. I tried couple of them, but still no lucky. With some of them i got no light at all.
                • matwPL
                  Bios for mini PC Beelink EQi12 Intel® Core
                  by matwPL
                  I'm looking for a BIOS dump for my computer, which I bricked by flashing the wrong BIOS version.
                  My computer is a Beelink EQi12 with an Intel® Core i5-12450H and 24GB DDR5 RAM. The BIOS version I'm interested in is EQI12204 or any other compatible version for this device.
                  I would be extremely grateful for any help in repairing my computer.
                  post moved..
                  03-12-2025, 01:58 AM
                • macabook
                  by macabook
                  🧩 Initial Issue
                  07-24-2025, 02:17 PM
                • Vesko356
                  by Vesko356
                  08-11-2023, 03:27 AM
                • limann
                  Bios HP EliteDesk 800 G3 Mini 65W
                  by limann
                  I need Bios for HP EliteDesk 800 G3 Mini 65W, please support
                  *Serial No : 8CG7427T48
                  *MB Info : Scorpius MB Rev A
                  16515-1
                  348.06N35.0011
                  *Proplem : No power on - 3 flashing red & 5 white, speaker : beep bep beep
                  Thank you...
                  10-02-2025, 07:53 PM
                • Datahoarder
                  HP Elitedesk 800 G2 DM / Mini -> Can't get BIOS flashed, tried multiple. Update Brick
                  by Datahoarder
                  HP EliteDesk 800 G2 MINI/DM (1L PC)
                  I have 40 of these units. All of which i tried to update bios with HP's utility got bricked. All of them were bios password locked, i used the jumper thing to reset it. Couple updated bios, one of which worked fine for _ONE_ boot. Second is now mixed with rest, i don't know which it is specifically so have not retested it.
                  All had some MESpilock failed errors on (my) first boot of the unit.
                  Photo: https://cdn.discordapp.com/attachmen...018_220853.jpg
                  10-19-2023, 09:33 AM
