Hi. I got an Beelink u55, which won't boot. Just white and blue light for 5 seconds, and then it shuts down. I noticed that something drains Bios battery. I have put new one, but after short time voltage drops from 3+ to 2volts. I didn't find any obvious short on board. Not ssd and ram issue. Does somebody have bios dump for this model? I would try that solution too. Serial number is 5005U1EF10180.
I need help with mini pc Beelink u55 bios
Tags: None
Here is original BIOS dump. It is GigaDevice 24q64CWIG. I can't even find exe bios update online. I desoldered bios chip, and after that bios battery is not drain anymore. So i suppose it's firmware problem, or the bios chip itself.Attached Files -
I'm sorry i'm going to explain myself.
I have a Beelink U55 that is now bricked after a bios update (which someone else did).
Reading a little bit more i discovered that this update was for the EC (that is the 1mbit chip i was referring to) and i managed to find the correct EC .bin on the beelink website and flash it. (It would still be useful to compare the two if you can get a dump of yours, i managed to do it without dissoldering it and connecting with the SOP8 claws). I will PM you with the link.
My minipc is still bricked tho, i will look into the Q64CWIG (big chip) in the following days and provide my dump if it can be useful.Comment
Thanks. I tried couple of them, but still no lucky. With some of them i got no light at all.Beelink U55 bios updates https://dr.bee-link.cn/?dir=uploads%2FEQ%2FU55%2FBIOSComment
by matwPLHi,
I'm looking for a BIOS dump for my computer, which I bricked by flashing the wrong BIOS version.
My computer is a Beelink EQi12 with an Intel® Core i5-12450H and 24GB DDR5 RAM. The BIOS version I'm interested in is EQI12204 or any other compatible version for this device.
I would be extremely grateful for any help in repairing my computer.
post moved..-
by macabookHello everyone,
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by limannHello,
I need Bios for HP EliteDesk 800 G3 Mini 65W, please support
*Serial No : 8CG7427T48
*MB Info : Scorpius MB Rev A
16515-1
348.06N35.0011
*Proplem : No power on - 3 flashing red & 5 white, speaker : beep bep beep
Thank you...-
by DatahoarderHP EliteDesk 800 G2 MINI/DM (1L PC)
I have 40 of these units. All of which i tried to update bios with HP's utility got bricked. All of them were bios password locked, i used the jumper thing to reset it. Couple updated bios, one of which worked fine for _ONE_ boot. Second is now mixed with rest, i don't know which it is specifically so have not retested it.
All had some MESpilock failed errors on (my) first boot of the unit.
Photo: https://cdn.discordapp.com/attachmen...018_220853.jpg
- Loading...
