H-Joshua-H61-uATX schematic
  • kanaia69
    • Sep 2018
    • 7
    • spain
    Hi Colleages!
    I was updating the bios of this motherboard H-Joshua-H61-uATX and suddenly the energy of the street was shutting down during the update. Now i have a motherboard with a corrupted bios
    I'm trying to use a ch431 programmer to update the bios but i'm not sure if i'm selecting correctly the bios chip. So in this case, i need the schemtatic of this motherboard to see if i'm doing well.
    On the other side, i have seen a jumper on motheboard that is written "bios recovery". Anyone knows if this can use to recovery the bios?
    Thank you for you help.
  • Zorromorais@gmail.com
    • Jul 2025
    • Moçambique
    Boa noite familia sou Jamuno tecnico novato e gostaria de fazer parte na badcaps
      • 21836
      This is an English language forum...
      • macabook
        by macabook
        🧩 Initial Issue
        07-24-2025, 02:17 PM
      • sssssssssssssss
        Need BIOS for HP Pavilion 15-n058sr recovery - Caps Lock blinking twice
        by sssssssssssssss
        I'm dealing with a classic BIOS corruption issue on an HP Pavilion 15-n058sr and hoping someone here might have the original BIOS file or point me in the right direction.
        Symptoms:
        • Laptop powers on but no display at all (completely black screen)
        • Caps Lock blinks twice with a pause, then repeats continuously
        • F12 LED stays on permanently
        • No POST, no boot sequence, nothing on screen
        Based on HP diagnostic codes, the 2-blink Caps Lock pattern indicates BIOS corruption/failure.
        What I've tried:
        • Hardware reset (battery removal, power
        09-04-2025, 06:45 AM
      • The_Memory_Guy
        Dell T7820 stuck in Bios Recovery Mode
        by The_Memory_Guy
        HI,
        I have a Dell T7820 stuck in Bios recovery mode. I never get Dell Boot screen or anything visible on screen. The system just gives me 3 white lights and 3 orange lights indicating Bios recovery mode.
        What I have tried to get to recover the Bios, there seems to be some conflicting advice about recovering the system.
        All of them say to download the latest bios from the dell website which is a .exe file. I have done that
        https://www.dell.com/support/product...BUT090/drivers
        Some...
        07-07-2025, 06:52 AM
      • mikinana64
        Fujitsu U939X BIOS Recovery (EC Corrupt)
        by mikinana64
        I was clean install Windows 10 Pro without installing driver, because i believe windows will download itself.
        But 2 days later it hard bricked, just battery LED charge indicator when plugged in, no boot or even post. Unplugging the battery will result zero response, LED flicker 0.1s and then everything turned off, no response to any button. Main BIOS powered 3.3V but EC is 0V.
        So i though it just BIOS corrupted, and confirmed EC BIOS has been corrupted (First header is 55 AA 01 00 FF FF FF and the rest is always FF FF until offset 10000 with 00 00 blank and 11000 where...
        10-23-2025, 02:13 AM
      • jendkkd jeje
        Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
        by jendkkd jeje
        So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
        I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
        10-11-2024, 03:12 PM
