Gtx 780 boardview and schematic
  • cappercan
    • Apr 2023
    Iam looking for a Evga Gtx 780 schematic and board view.
    The 780 possidon board view is not close.
    Dicky96 has the schematic that would help. I seen a video on YouTube that he was working on gtx 780. If he could post the schematic that would help alot.
    Thanks.
  • hpboy
    EVGA RTX 2080ti Boardview Schematic
    by hpboy
    Hi All,
    Does any have a boardview or schematic for the EVGA RTX 2080ti (11G-P4-2383-KR)?
    01-09-2025, 07:45 AM
  • PacoGT
    HP ENVY x360 gidget 8L 203038-1, boardview and schematic need
    by PacoGT
    hello firends
    i search the schematic or boardview
    I have this motherboard, but I can't find the schematic or the boardview.
    The problem is that on the chip marked where 3V should be, there are 5 volts, which indicates that the two are connected.
    So the computer doesn't turn on, and the 3V disappears after a few seconds.
    The original problem was that when I turned off the computer, the fan stayed on and saw that it was bad since it was directly in the 5V area.
    The new problem arose after removing the bad chip.
    3V and 5V remained together,...
    08-19-2025, 08:25 PM
  • hosain0489
    Request for Schematic and Boardview for HP Omen 16-xf0006AX (AMD Ryzen 7 7840H Version)
    by hosain0489
    I’m looking for the schematic and boardview files specifically for the AMD version of the HP Omen 16 laptop, model xf0006AX, equipped with the Ryzen 7 7840H CPU.
    Most of the files I’ve found are for Intel CPU versions, and I need the exact files for this AMD Ryzen 7 7840H model to assist with repair and troubleshooting.
    If anyone has access to these files or can kindly share the boardview and schematic for this particular AMD version, I would really appreciate your support.
    Thank you very much in advance!
    07-15-2025, 11:20 AM
  • tonycstech
    EVGA 1070 schematic and boardview please?
    by tonycstech
    I think i looked long enough (couple of months now) for a board view for my card
    EVGA 1070 and i cant find any.
    All i find are similar cards and a PDF format boardview which isnt very helpful when it comes to tracing connections.
    Schematics i have are for 1080, the values for caps and resistors are wildly different, i cannot use it for the purpose of identifying component values.
    Does anybody know where to get boardview for EVGA 1070 ?
    03-25-2022, 01:23 AM
  • re-atari
    Gigabyte GA-H110-D3A schematic/boardview needed
    by re-atari
    Hello all,
    Does anybody have a schematic and/or boardview of the Gigabyte GA-H110-D3A mainboard available? It would really help me out big time...
    This board was donated to me in a known non-working state. In its previous life it was used as a mining board, so I suspected bad caps and a relatively easy fix. My intention is to use the fixed board as a testbed for a Truenas or Unraid build. The previous owner told me that the mainboard started to act 'weirdly' after replacing the originally installed Celeron for an i5-6400, varying from starting up irregularly to not at...
    02-24-2025, 06:45 PM
