MSI H410I PRO WIFI - bios mod, disable overcurrent protection
  • sant1
    • May 2014
    • 11
    • Estonia
    Could someone disable USB over-current protection in this bios? Message is displayed over display-port: "Over Current Have Been Detected On Your USB Device!! System will shutdown after 15 seconds to protect your mainboard!!"
    Attached dump to this post.
    Diagnosed and come to a conclusion that PCH is faulty, there are overcurrent voltage dividers (net names OC#0 to OC#7) on USB power lines, dividers output is nearly 0V, PCH is pulling some of them down. Dividers resistors values are ok and data lines and VCC are not shorted.
    Thank you.
  • sant1
    • May 2014
    • 11
    • Estonia
    Found article how its done, but thats over my skills. Everything is well written except the bios modding part, no comments, only pictures.
    https://github.com/kholia/UEFI-BIOS-...readme-ov-file
    • Mr.Ultimate
      Alienware 13R3 bios mod request - to disable dedicated graphics (dgpu failure)
      by Mr.Ultimate
      Hi everyone, hope to get someone to help and modify bios rom for me.
      I need to disable dedicated nvidia graphics chip permanently.
      GPU chip had failed(cracked silicon DIE) and I can only use laptop without failing if I disable nvidia graphics in dev manager (but it still draws power from battery and generates thermal signature.
      Ideally if it was disabled from bios at preboot.
      I believe it is possible, because if I attatch external alienware graphics amplifier , laptop at boot will disable dedicated graphics #1 (failed one) and will only boot with AGA...
      08-06-2024, 05:15 AM
    • pirati
      by pirati
      10-27-2025, 04:20 PM
      by Vesko356
      08-11-2023, 03:27 AM
    • jbonavita
      by jbonavita
      Some issues
      Things I tried
      04-29-2025, 09:38 PM
    • Wahaz
      by Wahaz
      10-30-2023, 08:42 PM
