ECS H61H2-M13(1.0) 4mb
  • aboumohamed
    • Dec 2018
    • 258
    • algeria
    i need dump for ECS H61H2-M13(1.0) 4mb
    • 21472
    Post your bios backup.
    • aboumohamed
      • Dec 2018
      • 258
      • algeria
      thank you very much, I found a file of a good new bios
      • peste
        • 13209
        • ROMANIA
        try..
        • aziz77
          • Jun 2021
          • algeria
          TANK YOU GOOD MAN
          • techno repair
            • Sep 2022
            • algeria
            thank you mohamed
            • Citymin
              by Citymin
              S/N : 5RNK9FFT70...
              08-05-2025, 05:12 AM
            • m1ch43lzm
              by m1ch43lzm
              Hi everyone
              09-06-2025, 05:47 PM
            • bondminer009
              Need Bios for Latitude 7650 (No Original / dump bios file)
              by bondminer009
              Good Evening,
              Need help, is there any possible to get the bios file? Because received from my team without any dump file / original bios file
              Thank You
              Salam,
              Three
              11-12-2024, 07:48 AM
            • joshAU
              BIOS file for N550JK (original dump attached)
              by joshAU
              Hi all.
              I'm looking for a BIOS file for an Asus N550JK.
              I have a Asus R552J, which I believe is identical to the Asus N550JK.
              I downloaded the latest BIOS (210) for the R552.
              It is named N550JKAS.210.
              The BIOS file is however only 6mb in size.
              I've read the chip with a CH341A programmer and verified the file.
              That file is actually 8mb in size.
              I'm wanting to remove the BIOS password from this unit.
              It prompts you to input the password when turned on, so its sort of behaving like a power on password rather than...
              08-09-2022, 08:06 PM
            • adelage
              Merge ECS Z77-H2 bios cap file with original dump
              by adelage
              I am trying to recover an ECS Z77-H2 motherboard, I dumped the original bios with a ch341a programmer, the bios from the manufacturer is a .cap file of smaller size, and it seems that I need to merge this file with other information from the dump, anyone can explain how to do that?
              03-11-2025, 03:07 AM
