HP EliteDesk 800 G4 35W DM Desktop Mini PC - not posting after BIOS reset attempt
  • llek100
    • Aug 2024
    • 11
    • Slovakia
    Hello, sorry for the long post, I just wanted to include any details that might help.
    A bit of backstory - I currently have 5 of these MiniPCs - I got them for very cheap from Ebay. All of these PCs are BIOS administrator password locked without their drives.
    I also got a G3 large tower, that I could reset the password of fine just using a header and a button on the motherboard.
    So I thought that I could do the same with the G4 MiniPCs, oh how wrong I was.
    First of all, I stumbled upon a tutorial, that apparently showed a BIOS password reset procedure - where I basically removed a PSWD header on the motherboard, removed the CMOS battery and held down a yellow button on the MB and plugged in the power, I held down the button for three restarts.
    Then I put the header back, put back the battery and turned on the system - and the BIOS should have been unlocked. This was not the case and I ended up with three bricked MiniPCs.
    This is what they are doing now: https://drive.google.com/file/d/1YN-...ew?usp=sharing
    I am uploading all the BIOSes, number 1,2,3 do not post at all - like in the video - and are BIOS administrator password locked. And number 4,5 do post fine, but only are BIOS administrator password locked.
    Serial Numbers:
    1. - 8CC8471NLV
    2. - 8CC8471NL3
    3. - 8CC8471NLF
    4. - 8CC8471NLT
    5. - 8CC8420TJ9
    The BIOS files are here, since they exceed the filesize limit: https://drive.google.com/file/d/115V...ew?usp=sharing
    Please let me know if I posted anything that should not be here, this is my first time using this forum .
    Thank you!
  • hoaca388
    Badcaps
    • Jan 2022
    • 11807
    Backup bios files ? ( Compress them with winrar or 7zip and post them here.)
    • llek100
      • Aug 2024
      • 11
      • Slovakia
      Sorry, I did post them but through a Google Drive link in the post. Here they are in two zip files, numbered.
      I did not realise the upload size limit is per file.
      • llek100
        • Aug 2024
        • 11
        • Slovakia
        So an update, I managed to unlock the BIOS-4-5 using an HP unlock python script.
        This is the one if someone wants to do the same: https://gist.github.com/schorschii/7...7b65ff22c27337
        You also only need to read, unlock and flash the larger 16pin XU21 chip.
        However, I am still unable to boot the PCs with the bricked BIOSes - those are 1, 2 and 3. If someone would be able to help somehow rebuild the BIOS or something.
        I am not familiar with fixing possibly corrupter BIOSes.
        • hoaca388
          Badcaps
          • Jan 2022
          • 11807
          Fix error , unlock yet. Use Hp unloker or RC unlocker to solve the problem.
          • llek100
            • Aug 2024
            • 11
            • Slovakia
            Thank you so, so much! Number 1 and 3 do work completely fine now!
            Number 2 flashes 6 times red and 3 times white. I don't know if that's fixable. It is possible that the backup file for 2 was somehow corrupted or something, since it was the first one that I grabbed the backup from, and was the one I tested a MPM unlocked BIOS that was present on this website, but was deleted because it did not work.
            • hoaca388
              Badcaps
              • Jan 2022
              • 11807
              Try
              • llek100
                • Aug 2024
                • 11
                • Slovakia
                Unfortunately still the same with 2.
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 11807
                  Check hardware.
                  • llek100
                    • Aug 2024
                    • 11
                    • Slovakia
                    Hello, it now works! I had to erase the PRVROM, or the XU68 chip on the mother board, the system then recovered it! Now everything works!
                    Thank you very much for everything!
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 11807
                      • llek100
                        • Aug 2024
                        • 11
                        • Slovakia
                        Please one more thing, the number 2 has started showing the "There is a problem with the HP Endpoint Security Controller on the unti.", I am attaching a photo as well.
                        I am also attaching current BIOS dump. I do not know if this is fixable, since I am missing the original XU68/PRVROM backup from this device.
                        Also if there is a way I could support your work, please let me know.
                        Thank you very much!
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 11807
                          https://www.badcaps.net/forum/troubleshooting-hardware-devices-and-electronics-theory/troubleshooting-laptops-tablets-and-mobile-devices/bios-requests-only/3305683-i-have-hp-probook-
                          https://www.badcaps.net/forum/troubleshooting-hardware-devices-and-electronics-theory/troubleshooting-laptops-tablets-and-mobile-devices/bios-requests-only/3325398-hp-clean-vss2-dumps-fix-endpoint-security-error
                          • YG007
                            Asus BIOS How To Reset To Default Settings?
                            by YG007
                            Hello... Where do I start. I have 2 questions/scenarios that might bring this laptop back to life, so here it goes!
                            I have this laptop (Asus UX52VS) where I was flashing the BIOS to it and it froze during the process. I didn't have a reliable BIOS chip programmer at the time (It was a CH341A USB Programmer from Amazon where it took hours just to get the clamp on the chip and then every time I read, it gave me different results/corruption, and never would pass the verify test as no 2 reads were the same data), so I brought it to a shop. They had it for almost 2 months, but during...
                            06-05-2023, 08:22 PM
                          • Vesko356
                            by Vesko356
                            08-11-2023, 03:27 AM
                          • tay147895412
                            HP EliteDesk 705 G1 mini request for bios modding
                            by tay147895412
                            Hi, I have an HP EliteDesk 705 G1 mini.
                            Model: HP EliteDesk 705 G1 Desktop Mini
                            Processor: AMD PRO A8-7600B
                            Motherboard PCB Marking: "APCB M3 94V-0" / "NPGC N-150TL"
                            BIOS Chip: Winbond 25PE20VG (2 Mbit SPI, 3.3V, 8-pin SOIC) and MX25L6473E 64Mbit (8MB), SPI NOR, 3.3V, 8-pin SOIC
                            Could someone help me with my bios , request:
                            unlock MPM/DMI with a BIOS patch/mod , dc tay42069 if someone could help me pls
                            Im gonna leave down below my working bios, if someone could mod it so it has the mpm...
                            07-02-2025, 02:23 PM
                          • jbonavita
                            by jbonavita
                            Some issues
                            Things I tried
                            04-29-2025, 09:38 PM
                          • Wahaz
                            by Wahaz
                            10-30-2023, 08:42 PM
