P330 Tiny, type 30CF bios
  • PandaBoy
    Ivan
    • 8
    Hello and thanks for your help.
    Mine is a P330 Tiny, type 30CF with serial number: PC0ZFVT4
    No post, no screen.
    Motherboard Model: IQ3X0IL, EQ-370, NM-B551
    JBIOS1: W25Q128JVSQ
    JBIOS1: W25Q64JVSIQ
    I am attaching the downloaded BIOS.
    Would you assist me?
    Thanks!
  • PandaBoy
    Ivan
    • 8
    Can anyone help?
    • hoaca388
      Badcaps
      • Jan 2022
      • 12392
      Originally posted by PandaBoy
      Can anyone help?
      I can't find the SKU of this Me version. Click image for larger version  Name:	2024-05-17 16_54_48-.png Views:	0 Size:	91.0 KB ID:	3272525
      • PandaBoy
        Ivan
        • 8
        Thanks for the time! I don't quite understand... Do you need a SKU? I looked at the PC case, but there is no SKU there.
        • piernov
          • Jan 2016
          • 4439
          • France
          Invalid probably due to corruption, should be Corporate H. BIOS region also looks corrupted.
          • PandaBoy
            Ivan
            • 8
            Are you saying there is a hardware problem?
            • hoaca388
              Badcaps
              • Jan 2022
              • 12392
              Ok, tomorrow i try again
                • 22077
                He`s saying both your bios are corrupt. Try these
                • hotcrossedbuns999
                  M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                  by hotcrossedbuns999
                  My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                  1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                  2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                  3. I could only locate two chips that look like bios chips. Could someone verify this
                  01-03-2025, 12:32 PM
                • macabook
                  by macabook
                  🧩 Initial Issue
                  07-24-2025, 02:17 PM
                • pirati
                  by pirati
                  10-27-2025, 04:20 PM
                • abhorsen
                  Help Disabling Flash Protection Range Registers on Lenovo P360 Tiny BIOS
                  by abhorsen
                  Hey guys,
                  Hope you all are doing well. I come here from Win-Raid because I am having issues disabling Flash Protection Range Registers so I can flash my BIOS from within Windows using Intel's IFW tool/using flashrom within Linux, however I cannot due to the above mentioned error.
                  Here is my thread on Win-Raid detailing the whole process I went through: https://winraid.level1techs.com/t/re...h-gen/95478/27
                  Essentially I managed to boot into Windows while shorting PINs 1+5 of my audio chip to disable the HAP bit...
                  07-06-2023, 10:22 AM
                  by Vesko356
                  08-11-2023, 03:27 AM
